Interior/Exterior TSX xenon projector retrofit
I just bought a xenon kit, but the result is not as good compare to xenons with projector. To resolve this issue, I just bought two set of TSX projectors (S2000 are the best, but TSX is cheap and the result is still fairly better many others). I was thinking running 4 low beams and replace the highbeam since I will never use them.
Here is my concern, I after looking through several post in NAM, people had trouble disassemble the headlights because there are three bolts holding the unit together. Is there a solution for this? Also, what is the best technique to take the headlight apart: oven, heat gun, or dremel? For the folks that done similar project please help me. Thank you
BTW, the xenon kit is out and Vision Plus is back on.
the oven is most often the easiest and safest option. are the TSX the ones that you can mod to get the greater color cutoff? if you've never been, you should check out hidplanet.com a lot of very useful information on there.
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
