BBS - custom rims for R90s and R98s
Old Jun 8, 2007 | 03:05 PM
70spop's Avatar
70spop
Does anyone know if BBS will do different rim widths/offsets for two-piece wheels like the R90 and R98? Prolly expensive, but it would be fun to get a set of 7.5 or 8 inch wide R90s with a +40 or +45 offset.
Old Jun 9, 2007 | 05:20 AM
Passat774's Avatar
Passat774
I have already tried and they said nope :(
The other option is just to have them made wider on your own.
Old Jun 9, 2007 | 07:24 AM
goin440's Avatar
goin440
I didn't think they were actually even 2pc, just look.
Old Jun 9, 2007 | 08:04 AM
Passat774's Avatar
Passat774
They are 2 pc wheels
Old Jun 9, 2007 | 08:08 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I agree....but what are the 2 pieces. These arent like my 2 piece BBS's that allowed me to widen by adding large lips. Does just the center come out...or is the barrel removable. Either way....it doesnt offer widening capabilities that would help anything.
edit: 17" R90s are two piece....16" r90's arent. Just throwing that in there.
Old Jun 9, 2007 | 08:12 AM
Rally@StanceDesign
If you're gonna get wider BBS and get them custom widened i certainly hope you wouldnt go with those offsets Atleast space them out properly if you're going custom.
Atleast stay away from the 45....40 would be okay with the 8's and 35 would be nice for 7.5's
Old Jun 9, 2007 | 08:16 AM
Passat774's Avatar
Passat774
You are right they are centers and barrells. So, you can not just add a larger front lip like you are doing..
Old Jun 9, 2007 | 08:24 AM
Rally@StanceDesign
So you could widen them.....but it would only raise the offset from what it is now. And i dont know how wide you could go on the barrel without hitting the shocks....but i bet you could get to a 17x8.
So now all you have to do is take apart your r90's....measure the specs of the barrel and its holes, and send it in to kodiak, schmidt (germany), or image (UK) and have them make you some custom barrels. They wouldn't look wider standing outside the car....but you would have 8's under there.
Old Jun 9, 2007 | 05:48 PM
70spop's Avatar
70spop
I know the look you like, Rally. I'm not having that conversation again.
I've seen several cars with 7.5 wide wheels with +40 offset, and I personally like how that set-up fits. +35 would work fine, too, I'm sure. I mean really, 5mm doesn't do that much, and the +40 still has a little room.
For 8s, I don't think I'd go any lower (numerically) than +40. Given the same offset, the rim is going to be 12.7mm further out (and in, on the inside) than a 7" wide wheel. Add 10mm to that going from a +50 to a +40 and you're going to be about a whole inch further out. If I were getting an 8" wide wheel, it would be to run 235/40-17 tires. If you were sticking to a 205 or 215 width and wanted some stretch, then you could probably pull off a deeper offset with the 8s and still keep the tread under the fenders.
Old Jun 9, 2007 | 05:49 PM
70spop's Avatar
70spop
Oh well. Not that I have a set to widen anyway, just thinkin' out loud.
freeman727
Dec 10, 2017 04:00 AM
NYMADMINI
Dec 14, 2016 02:33 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
krohm
Sep 28, 2015 12:16 PM
2011minnie
Sep 27, 2015 10:44 AM
