JCW steering wheel, horn not functioning
As the title implies, I have an upgraded jcw steering wheel, but the horn does not work. I did not do the the install, and it seems probable that someone simply missed the wire for the horn.
Are there any other possibilities I could try before removing the wheel? Is it possible that this is not a first gen JCW steering wheel? or would that not fit? |
Just pull the airbag and make sure the one ground wire is connected. That is the only wire for the horn in the steering wheel.
a review of your posts suggests you bought this car to 'track'
if I am wrong ... stop here on the other hand did you TEST the horn b4 you bought the car? Have you looked at the fuse for the horn? Has you applied a meter at the horn connection? |
No, this is not a track car. Fuse is fine. I have not checked voltage at the horn.
Sounds like the cable was not clipped in. Disconnect the battery before you unhook the airbag.
^ Will do.
I guess I should have mentioned, the radio/cruise controls all work. I suppose the horn cable is easier to miss. |
I tested the voltage at the horn connection, solid 12v. Looks like the horns need replacing.
Yep,sounds like the problem, thanks for the update.
