Question about JCW carbon fiber hood scoop
Subscribe
Nov 10, 2008 | 08:50 AM
I just replaced my stock hood scoop with the JCW carbon fiber one. There is a screw underneath the hood that was holding the stock scoop onto the hood. This screw does not work with the JCW scoop. It's too loose and does not tighten up. Those of you with JCW hood scoops, did you have a similar problem and what did you do about it? Does anyone know the part number for the screw that will work with the JCW scoop?
Reply 0
Nov 10, 2008 | 01:30 PM
I had a similar problem when installing mine. The screw became tight when it was only halfway 'in'. I didn't want to force it and end up with a damaged scoop, so I left it as it was, figuring the clips would hold it well, and if they somehow came loose, the screw would still stop it from flying off somewhere. So far, the scoop has held firm.
Reply 0
Subscribe
