JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW V.S helix 380's
Old Feb 13, 2008 | 10:24 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
JCW V.S helix 380's
Which one's should i go with for jans tune? Ive heard the helix's were maxxed out at 198whp....eeekk....help me out...
Old Feb 13, 2008 | 10:50 AM
MiniStupidfun's Avatar
MiniStupidfun
According to Jan the Helixs are harder to tune.
Old Feb 13, 2008 | 11:38 AM
the platform's Avatar
the platform
I receive my JCW's tomorrrow,for my Jan tune week from Fri.
Old Feb 13, 2008 | 01:47 PM
RedSkunk's Avatar
RedSkunk
I've heard numerous people say the Helixs max out sooner than the JCWs, but I say either would work if you're just doing "stage 1" mods. (The Helix injectors flowed me past 200whp.)
And if you're doing a head and other big buck mods, then you'll want larger injectors than 380cc, so it's a moot point. *shrug*
It's probably a question of a couple HP, so make the cost difference decision on that (what are they, $40 cheaper? Again, *shrug*)
Old Feb 13, 2008 | 01:48 PM
littlehandegan
Yeah im at 197 right not and lean up top quite bad....
Jack
Old Feb 13, 2008 | 02:08 PM
Ryephile's Avatar
Ryephile
While the Helix 380's look and feel like quality pieces [and part throttle drivability is very good too], I feel that for most modders going straight to 440cc/min injectors is the way to go.
Old Feb 13, 2008 | 03:06 PM
minimarks's Avatar
minimarks
JCW here....
Old Feb 13, 2008 | 03:10 PM
Maxicooper's Avatar
Maxicooper
I have JCW on my set up as well. It works perfectly fine.
Old Feb 13, 2008 | 03:17 PM
latte hiatus's Avatar
latte hiatus
Wouldn't 440cc/min be a bit too much unless headwork was done? With JCW 380cc/min injectors, my fuel trim was already on the high side at idle without a tune.
On another note, I've heard that the JCWs and Helix injectors have different spray patterns, since the JCWs retains the OEM spray and Helix is made by Bosch.
Old Feb 13, 2008 | 03:32 PM
AstroBlackS's Avatar
AstroBlackS
According to their site, The helix injectors are designed to split the flow so that each stream is directed toward the intake valves.
Old Feb 13, 2008 | 04:12 PM
Johan's Avatar
Johan
So do the stock and JCW
Old Feb 13, 2008 | 04:23 PM
sportygoggles's Avatar
sportygoggles
where can you get 440s?
Old Feb 13, 2008 | 04:35 PM
sknandigam's Avatar
sknandigam
Looks like OutMotoring sells the JCW 380s for 290. Are there any vendors that list them for less?
Old Feb 13, 2008 | 04:56 PM
Ryephile's Avatar
Ryephile
RMW has easy-to-tune Bosch pieces.
Regarding the fuel trim; the stock ECU can handle trimming out 440's, trust me, I did it on my single turbo setup R53, which is much more efficient than the M45 blower setup. What the ECU can't do is trim out anything larger than that.
Old Feb 13, 2008 | 06:21 PM
littlehandegan
So you think going straight to 440 is the better idea? Even w.o headwork etc.?
latte hiatus
Good to know, sir!
Old Feb 13, 2008 | 07:07 PM
Ryephile's Avatar
Ryephile
Yup. That way if you ever do decide to upgrade cylinder head/cam/header/whatever in the future, you already have the injector headroom.
Old Feb 13, 2008 | 07:25 PM
searocko's Avatar
searocko
Minspeed.net
Old Feb 13, 2008 | 09:05 PM
Larry Clemens's Avatar
Larry Clemens
My 2005 MCS w/ basic mods (15%, CAI, exhaust) started to run out of fuel at 6500 rpm with JCW 380s. BTW, check out my thread titled Dimsport Software in Roundel Magazine. In the Bimmer Lite (MINI) column, Dimsport software is recommended for MINIs with any mods to get them to perform optimally. The author does not mention a specific tuner but I think he was referring to RMW:
"The bottom line is that the only way to get a Mini to perform optimally with any modifications, the ECU needs to be custom-tuned. One effective way to do that is with Dimsport software: Find an outfit with it, set up an appointment, and they'll cook up an ECU tuned specifically for your application."
Old Feb 14, 2008 | 04:21 AM
sknandigam's Avatar
sknandigam
Stupid question: as you increase the flow rate of your injectors, is there a loss in gas mileage?
Old Feb 14, 2008 | 07:40 AM
Helix13mini's Avatar
Helix13mini
I asked him if this was true when he was ordering more Helix injectors yesterday, and he said no.
Old Feb 14, 2008 | 07:44 AM
Helix13mini
If you just put bigger injectors in your car without tuning it, and drive the car really hard, your milage will suffer. If you drive the car normally, it will adapt to the fuel volume difference of the bigger injectors and your milage will be very close to what you see now. BTW, if you have the on-board computer that calculates fuel milage, It will be thrown off by the bigger injectors, and will show that you are getting better milage than you are.
Old Feb 14, 2008 | 07:56 AM
RedSkunk's Avatar
RedSkunk
Wow, I wouldn't run 440s untuned for any length of time at all. You weren't using the stock tune with the turbo, were you ryephile? I think it makes sense to buy the 380s, since you can easily re-sell them at any point for a marginal loss. snM3 – not stupid, yes you'll probably get decreased mileage switching to larger injectors and not tuning for them. Tuned, it'll be similar mileage.. IF your driving stays the same.
Old Feb 14, 2008 | 09:32 AM
Revolution Mini Works's Avatar
I have not experienced any issues with the Helix injectors
they are the same as the JCW injectors from what I have seen on the dyno
they are Bosch style same as the 440cc I use .... the 440cc do require more tuning to get it right as they need to be scaled. I think here is where there might have been confusion.
Old Feb 14, 2008 | 10:42 AM
littlehandegan
So im not going to be robbed of power? Or capable tuning?
