Non-oem Pedal Change
I couldn't stand those little rubber booties that come on the MC pedals, and forget all those lame-o pedals availible through moss:roll: (no offense, moss). The MINI pedals are OK, but they have no flair. With a wing and a proverbial prayer I ordered the MOMO Stealth wide pedals for BMWs and Mercedes, hoping for a fit.
They fit pefect and look like they belong!:thumbsup: Here's a pic: https://www.northamericanmotoring.co...pedals-med.jpg Flashy, grippy and sturdy, plus they're european enough to be in my MINI. about $108 for the whole set from www.ltbmotorsports.com (best price) with free shipping for any order over $100- They fit exactly with some drilling- The clutch was the easiest, its plastic and lined right up; the accel has a waffle back and wasn't too bad to line up, but I used some washers to anchor the nuts on the back and I had to clip off the excess screw end; the brake pedal is metal so it took denting a starting spot, then holding a drill there for a minute to get through, still not too bad and again a perfect alignment; the dead pedal has a curve and the MOMO pedal does not, so I placed a felt pad under the bottom 1/3 the attatched the screws thru the plastic dead pedal (no nut) by hand so I didn't strip them. Enjoy another pedal choice with style!:grin: -[[[S]]] |
LTB Motorsports
careful if you go on the site, though, because the Le Mans pedal set from MOMO will not line up to drill onto the pedals-
Just a little "heads up".:wink: -[[[S]]] |
They look nice, question though.
They fit pefect and look like they belong!:thumbsup: Here's a pic: https://www.northamericanmotoring.co...pedals-med.jpg Flashy, grippy and sturdy, plus they're european enough to be in my MINI. about $108 for the whole set from www.ltbmotorsports.com (best price) with free shipping for any order over $100- They fit exactly with some drilling- The clutch was the easiest, its plastic and lined right up; the accel has a waffle back and wasn't too bad to line up, but I used some washers to anchor the nuts on the back and I had to clip off the excess screw end; the brake pedal is metal so it took denting a starting spot, then holding a drill there for a minute to get through, still not too bad and again a perfect alignment; the dead pedal has a curve and the MOMO pedal does not, so I placed a felt pad under the bottom 1/3 the attatched the screws thru the plastic dead pedal (no nut) by hand so I didn't strip them. Enjoy another pedal choice with style!:grin: -[[[S]]] Can't quite make that part of your picture out. Were able to add angle to the dead pedal? What is the surface of the pedals like for no slip when wet? |
They look nice. I had MOMO padels on my Miata and they were great. Enjoy!:thumbsup:
The gas pedal is symmetrical- just a rounded rectangle. The dead pedal is angled towards the back because of the pad underneath the bottom portion of the pedal. The pedal are machined and have pretty good grip- -I've had no slips even in some wet conditions. The bottom of each pedal has a rubber covering for even better grip. See the pics on the site where they sell them for a better pic of the pedal texture.
-[[[S]]] |
