Originally Posted by Mini-LSE
(Post 3673480)
I was looking into this too. Are they hard to swap out? http://mini.sewellparts.com/oem-cata...SLCI-2012.html |
Originally Posted by Weare138
(Post 3673631)
Yeah, but when you look at the actual part it says some kind of crazy grey "SCHIEFERGREY" not black, so is it the black line or is it grey? |
Originally Posted by Lady_May
(Post 3673830)
It's called Shiefergrey, which is a real black grey, nearly black, but not black.
Nevertheless it looks realy good and black. Saw at the dealer. |
Originally Posted by MBj
(Post 3673840)
Nevertheless it looks realy good and black. Saw at the dealer. Ahh, ok. I was getting confused when I was reading the parts. Thanks for the clarification! |
Here what they look on a black CM.
The grey is the same as the side cuttles. https://lh5.googleusercontent.com/-f...1CE1FD7B8A.JPG https://lh5.googleusercontent.com/-f...86DC28D466.JPG https://lh6.googleusercontent.com/-1...5DE9E74301.JPG |
that looks good. I think I may have to get these. as for swaping them out its just a lot of clips. i found a small flat tip screwdriver or a plactic pnl tool works on the rings. I took a look at my tail lights when i had to have the uk light mod done to mine.
Oooo. I was debating but after these pics I think I'm sold.
Here are the parts :
Headlights are european and will take some time to get in. http://www.ecstuning.com/Search/51132254023/ http://www.ecstuning.com/Search/51132254028/ Rear taillight trims : Are available in the US now http://www.ecstuning.com/Search/51132296301/ http://www.ecstuning.com/Search/51132296300/ Thanks |
Does anyone know if there's a blackline version of the boot lid handle (that big thick piece of chrome above the license plate)?
1 Attachment(s)
Originally Posted by komet155
(Post 3710161)
Thanks!
I just ordered the paintable one and will either paint it the same black as my roof OR body color. I'm going to photoshop the black option ahead of time to see if it goes well on my car with the black taillight frames on either side. I wouldnt want the back end to look too "busy." |
Komet , are you talking about the R56 version primed boot handle?
Yes, part #51132754240. I have a 2013 Cooper (non-S) which is equipped with a chrome handle.
(Post 3710852)
Yes,
Thought you were talking about a possible black line version of the R60 handle / emblem. You could get the primed version and paint or wrap it so if you ever go back to stock you will have your chrome version. R56 R57 models http://www.ecstuning.com/Search/51132754240/ES77826/ http://c1552172.r72.cf0.rackcdn.com/316618_x600.jpg I think it would go well with the Black Line Trim around the tailights. Also if you can paint it to match the exact color of the blackline w/ gloss. :thumbsup: |
Thanks! :)
It looks like this might actually be available now:
http://mini.sewellparts.com/oem-cata...60SX-2012.html I really dig the photos I've seen of the rear lights, but has anyone seen them ON a countryman? |
The kit is available for the rear black-line taillights with anthricite trims.
#1 Retrofit Kit For MINI Black Line Lights Part # 63212280158 http://www.ecstuning.com/Search/SiteSearch/63212280158/ http://realoem.com/bmw/diagrams/s/g/424.png The side turn signal lamps are not available yet. #3 63132221503 But the front headlight trim kit is to match the rears. Headlight Trim Ring Gray - Set #4 http://www.ecstuning.com/Search/SiteSearch/51132254023/ES2635829/ http://c1552172.r72.cf0.rackcdn.com/401493_x600.jpg Thanks |
