M7 Scoop installation...
3 Attachment(s)
Man...it was a pain:
The on-line instructions were helpfull but needed a little more info to be perfect. Like indicating the size of nut so users know what socket to use. The washers could have been larger so it covers the existing holes completely for a secure fit. A larger drill bit. According to the instructions, users are suppose to drill from the engine side of the bonnet to make a hole large enough to fit the socket. The 1/4" bit didn't help. Most of the installation time was spent using the drill bit to make the initial hole wide enought for my socket. A drill bit that would drill a hole large enough to accomodate a 3/8" or 10mm socket would've saved so much time and sweat, and would have resulted in a cleaner drill hole. Once I installed the screws the front screw and washer didn't tighting the scoop down enought so it moved side to side. Looking at the screw and washer it screwed all the way flush to the sheet metal inside the large opening made by the drill. Now I can't get to it and I had to rig an attachment straight to the bonnet. Now it's snug and doesn't move, but the detail is ugly. Lastly, looking at the scoop head-on shows an ugly detail. It looks unfinished. You would have thought they noticed this and added a nice black mesh. Vince |
From the front it DEFINITELY looks like something is missing...that makes my choices a little different as I was looking at getting the Vortex scoop too...
I think it looks pretty sweet as long as you're not looking directly into the scoop.
I have one too and it is S-H-I-T quality
Does any one have the CF version? I was thinking of going with that since I have the JCW CF scoop on my car. I was interested in the M7 Vortex scoop because it looks more aggressive.
M7 Vortex 2 Scoop
3 Attachment(s)
LOVE IT!!!!
M7 Vortex 2 Scoop
1 Attachment(s)
Works very well with the CF mirror caps. It is not near as aggressive as I thought it would be which is great! I think it looks edgey without being gaudy. Took awhile to get it in but well worth the wait in my opinion.
Just to confirm...
Vortex 2 Scoop does require drilling? I want to get the CF version cause my original hood is melting due to heat from the turbo. |
It does require drilling one hole.
I've got the parts but, so far, not the time to epoxy a piece of stainless mesh into the back of the scoop to reduce the amount of "road debris" that goes through the scoop and it'll be painted black. I'll also be masking off the entire hole when the scoop is out and I'll paint the inside of the hood area to get rid of the blue paint that shows when you look into the scoop. I've been running with a Scan Gauge this past week and I'm watching my intake air temps. It's been nice to see that my intake air temp runs 6-10 degrees above ambient. Anyone out there with a stock 2nd gen scoop checking their temps? I'm kind of curious what the difference is - if any. Just be prepared to pick leaves and stuff off the engine and out of the engine bay from time to time but otherwise, it's a nice set up! |
Drilling hole
Yes there is one hole that is drilled from the underside of the bonnet so you arent actually drilling thru the top side. I was worried about this when the direction and this thread talked about drilling a hole. Actually you are just continuing a factory drilled mounting hole that is already in the top side for the OEM scoop.
Sorry, but that looks like ass...
You really can't see the inside area that the scoop reveals unless you are bending down looking in there or you are 3ft tall.
I was going to paint the inside matte black but I decided it does not bother me enough to do so at this time. |
All in all i am really happy with the look
The only pain with the installation for me was trimming the bolts. The shop that i had paint the scoop didn't tape off the threads of the bolts so getting the paint out of the threads was not fun. Tried to just tighten the nut on the threads to get it of but ended up torqureing the bolt and having to epoxy back in place. |
A little more info about Vortex installation
Originally Posted by mickdayank
(Post 3039018)
Thanks. :confused: |
Info
Originally Posted by Deep_Blue
(Post 3080351)
Hi, sounds like you are one of the few with no complaints or problems with the M7 Vortex scoop. I just purchased one today and it will be here next week. I would really appreciate any tips you can suggest (even about removing the original scoop) so I don't become a complainer. I read the M7 installation instructions and viewed the uTube video, but I am still in the dark about the ease or difficulty of the installation. Any advice would be greatly appreciated.
2 Attachment(s)
Couple pics...have more just need to dig them up.
Found 'em
2 Attachment(s)
Here ye be.
Thanks very much for your thoughtful advice and suggestions--the idea about using the mesh is great because my old high school autoshop teacher warned us about birds and rocks coming through hood scoops, of course this was in the 1960s;). Thanks for your time and I will update my photos and let you know when the work is done. The photos in your gallery of your car look great!
And try real nuts. WING nuts? please. Get some nyloc's and fender washers.
