Seat Position Sensor Swap
10 Attachment(s)
Here's how to change your seat position sensor. I was having intermittent seat belts and SRS lights on the tach and speedo and it persisted even after clearing the codes. Though sometimes clearing the code worked for a few minutes of driving then the lights would return. INPA told me it was the seat position sensor. I looked under the seat and could not see anything wrong with it but I ordered a replacement from ECS and set about throwing a little money at the problem. It turned out the sensors wire was broken and only held together by a slim bit of the wires jacket. They would occasionally touch and the warning lights would turn off.
Here's what I did: What I used: Attachment 195953 Gloves (everything is sharp under a mini seat!), screwdrivers, T40 Star bit, Allen key (had to modify), hammer, pop-rivet gun, light 1. Disconnect the under seat wire connections and remove the 4 bolts holding down the seat. ***You may want to disconnect the battery before doing this operation.*** I choose not to disconnect the big yellow connector but to lean the seat back and carefully prop it to be sure not to pull that wire bundle. Attachment 195954 2. With the Seat leaning back against the back seats. Disconnect the electrical connector and cable restraint clip. Close up of wire: Attachment 195955 Attachment 195956 3. Using Allen key unscrew the singe Allen screw holding the sensor to the rail. Do this from under the seat. Replace the faulty sensor at this point. This is tight work and best done while you are in position. ***TIP: I had to cut about 1/2" from my Allen key to fit on the screw behind the rail. Attachment 195957 Attachment 195958 4. The magnet is encased in plastic and has a flat rivet on the bottom with its securing nub in the seat rail. Next using flat screwdriver and hammer knock off the rivet nub securing the permanent magnet to the seat rail. Attachment 195959 Magnet Attachment 195960 Magnet position Attachment 195961 5. Clip the included new magnet to the rail in the same position as the old one and use your riveter to secure the magnet with the included rivet. The stem of my rivet didn't want to snap off so I had to use my rotary tool to cut it off. Attachment 195962 6. Reattach the connectors, secure your seat back to the floor, and reconnect your battery if it was disconnected. That's it nice and easy. Enjoy not having warning lights on because of a faulty sensor. I did not have to clear the code as the ECU recognized that the fault was gone and turned off the warning lamps. |
Thx for the write up! I am having "Seat position sensor" faulty code(0093BF) after my recaro installed, Airbag light is still on because of that..
Even tho I cleared the actual "side airbag sensor" code(0093AC) with 3.3 ohm resistor and ISTA device. Looks like I need to perform transplanting the seat position sensor to my recaro rail and plug the connection. |
Nice write up the seat position sensor is right here: 52102752671
52102752671 R55 Clubaman / R56 Hardtop / R57 Convertible models http://www.ecstuning.com/Search/SiteSearch/52102752671/ http://c1552172.r72.cf0.rackcdn.com/253807_x600.jpg And the R60 Countryman Version Here: 52109802693 http://www.ecstuning.com/Search/SiteSearch/52109802693/ http://c1552172.r72.cf0.rackcdn.com/645642_x600.jpg thanks |
Hi. Need you advise. I have exactly the same problem as the topic-starter has. Computer also says the problem is in the seat position sensor. The only thing is my sensor wires are rubbed a bit, not as bad as TS has. But still those warning lights on my dash light up. Sometimes they got away when I touched that rubbed place on the wires. I tried to fix it because $50-$60 is a little bit too much for me. I've disconnected the sensor, isolated rubbed section and put it back. AND NOW the problem is that those 2 red warning lights on my dash don't turn off whatever I do. I thought that maybe I've broken one of those wires when isolating, dismounted sensor again, cut the wires in rubbed place and twisted the wires properly, isolated and put it back. Warning lights are still ON. What could be the problem? =(
