Mini Cooper R52 Alarm retrofit
15 Attachment(s)
OK so this one is a quick post, since the PDF instrucitons are here.
http://www.minipeople.lt/failai/db/2/audio_2calarm.pdf partslane.com 82110306852 65750029310 65750397059 alarm retrofit kit $259 So I'll just post up my pics to augment the PDF drawings. The only difficult part is that the rubber seals next to the seatbelts are fitted with single use push pegs. You cannot extract and reuse them. Try to maneuver the rubber out of the pegs or order two new pegs. Attachment 156938 Attachment 156939 Attachment 156940 Here you can see the fixings for the interior trim panel. Any metal clips that stay on the body, remove them and put them on the plastic for reassembly. Attachment 156941 Attachment 156942 Attachment 156943 Attachment 156944 Attachment 156945 Attachment 156946 Ordered the auto lights version for my RLS retrofit. Attachment 156947 Attachment 156948 Attachment 156949 Attachment 156950 Attachment 156951 Attachment 156952 Fairly self explanatory with the PDF instructions and the harness read waiting. Coding is required to activate the alarm. |
I know this is an old post but wanted to ask what coding needs to be done to my R50? I see in the retrofit coding options for an R56 it mentions adding $302 to your VO and defaulting the car. And maybe setting DWA to aktiv in the BC1 module. Will this work for an R50 also?
