Mini Cooper Clutch Kit Os Giken Grand Touring R52 R53
Subscribe
Dec 17, 2015 | 08:26 AM
Part No: NMG1633
SALE Price $1790.00
Was: $1,895.00
You save: $105.00
This is Special Order Only Item
Fits the following models with the 6-Speed Manual Transmission:
2002-2006 R53 MINI Cooper S Hatchback
2005-2008 R52 MINI Cooper S Convertible
High Quality Grand Touring Clutch and Flywheel Upgrade kit from OS Giken for your MINI. A performance street set-up with 'stock-like' pedal pressure perfect for daily driving. Giken products costs slightly more than the factory flywheel and clutch replacements, but offers higher quality and durability. The integrated flywheel, clutch, and pressure plate design provides a 'matched' and 'balanced' solution.
What is the difference between an OS Giken clutch and another companies clutch?
Through years of development and since its first introduction to the public in 1983, OS Giken clutches have always focused on extraordinary durability, drivability, and effective power transmission. In order to properly develop a clutch system to maximize drivetrain performance, OS Giken determined that it would be most effective to engineer and manufacture clutch kits as a clutch/flywheel package. By doing so, a clutch kit can be installed which has already been properly matched to your MINI. Additionally, the design, engineering and manufacturing of OS Giken clutch kits promote improved durability (through friction plate material which is carefully selected and alloyed so that the plates match with the materials of the flywheel and center plate), maintained drivability (through revised leverage mechanisms to provide higher disk pressure while reducing pedal effort), increased longevity (through a superior design and usage of extra manufacturing processes for strengthening).
For a more 'Performance' oriented Clutch/Flywheel upgrade, see NMG1630 Performance upgrade kit.
For the 2007+ R56 Cooper S Hatchback, 2008+ R55 Cooper S CLUBMAN, and 2009+ R57 Cooper S Converbibles, see G2NMG1640.
Kit includes Clutch Disc, Pressure Plate, Flywheel, Flywheel Bolts and a metal Throwout Bearing. Enclosed Flywheel Bolts MUST be used with this kit.
For matching OS Giken Super Lock Limited Slip Differential, take a look at NMG1010.
If you need a rebuild kit for these clutches, see Mini Cooper Clutch Kit Overhaul Kits.
Reply 0
Subscribe
