Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
ST43 pads
Old Nov 14, 2017 | 06:00 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
ST43 pads
anyone run ST43 pads? I tried the new wilwood BP-40 last weekend but I destroyed a set. I was happy with the bp40 performance except for wear, same with xp12 IMO, also happy with dtc60 except for the terrible rusting dust.
Thinking of giving st43 a try, I'm running 7816 pads
Old Feb 14, 2018 | 05:20 AM
MrBlah's Avatar
MrBlah
The st43 worked great, .8mm pad wear on the front at a track I've used up a whole set of fronts in a day at.
rotor temp 1000 degrees, no fade
Old Mar 1, 2018 | 07:26 AM
MrBlah's Avatar
MrBlah
Used same set at VIR this past weekend, full saturday and grand sunday.
Now at 7mm pad left with a little taper so I flipped the pads. I'm pretty happy with these pads, not too much bite for street tires, wear could be better but I'm at the temp limit for these pads, I could go to ST47 but they have a lot more torque so I'm sticking with these for now.
Old Mar 1, 2018 | 07:36 AM
Minibeagle's Avatar
Minibeagle
What thermal graphic heat paint do you use and where do you get it, mega72?
Old Mar 1, 2018 | 08:37 AM
MrBlah's Avatar
MrBlah
Genesis paint you can get it on Amazon or race part stores
