R50/53 Pollen Filter Replacement?
Old Aug 21, 2009 | 09:06 PM
Justin1114's Avatar
Justin1114
Just wondering if anyone replaces their pollen filters in the cowl vent? Mine has totally disintegrated. I was thinking of just cutting an air conditioner filter to size to replace it. What do you guys think?
Old Aug 24, 2009 | 07:44 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
You mean cutting a piece of foam to fit? I guess it would work but I get an aftermarket filter for about $12 that fits like OEM, works fine and lasts for a couple of years.
Old Aug 24, 2009 | 09:07 AM
03BRG's Avatar
03BRG
They would replace them under warranty for that problem. The "new ones" do not use the foam anymore.
Old Aug 24, 2009 | 03:43 PM
Capt_bj's Avatar
Capt_bj
presuming U R talking about the soft mesh used on the 02's .... like U mine disintigrated long ago
The new version used nothing in there but I wanted something ....
I cut a piece of stainless gutter guard material and it fit into the spot wonderfully.
Gutter Guard - 1 piece - under $4
time ..... under 10 minutes
Old Aug 24, 2009 | 06:59 PM
Justin1114's Avatar
Justin1114
Thanks for the input, I may try the gutter guard material. I prefer the DIY if it looks good if not I guess I'll just buy new ones.
Old Aug 24, 2009 | 07:30 PM
ron-s mini's Avatar
ron-s mini
Do a search -- there are some good threads on cabin filters.
Old Aug 25, 2009 | 03:58 AM
Capt_bj's Avatar
Capt_bj
I don't believe we're talking the actual inside the cabin filter .... I know I'm not.
The plastic cowl vents in front of the windshield had a foam insert on the 02 (maybe 03 as well). It didn't hold up....but it didn't do anything either. Later years just redesigned the part w/out the foam insert & would simply give you the newer plastic part w/out the foam if you called 'em on it under warranty. I didn't futz with it 'til after that.
Not the same as the oft' discussed paper element for the cabin filter.
Old Aug 25, 2009 | 06:59 AM
ernesto's Avatar
ernesto
Coordinator :: Chicago MINI Motoring Club
I used window screen mesh to replace the worn out foam in my cowl vent. I used metal because that is what I had at home, but if I was to do it over again, I'd use fiberglass so there would be less sharp edges to trim and clean up.
Old Aug 25, 2009 | 02:29 PM
Capt_bj's Avatar
Capt_bj
yep - I did the same using a tight mesh gutter guard - a little tuffer to cut if you don't have the right tool. I like how it came out - sorry car is gone and I never took a picture.
FYI anyone who likes the look - the early cowl vent could be opened up to replace that foam and allows a substitute to be inserted. The new version does not.....you can't easily add something to get the same look.
Old Aug 26, 2009 | 07:41 PM
Justin1114's Avatar
Justin1114
That looks pretty nice Ernesto. I think I may try it. Thanks for the photos. The gutter guard is a good idea but I think It will be a little easier to cut the screen. Thanks for your help guys.
Old Sep 2, 2009 | 03:15 PM
grc123's Avatar
grc123
Very nice pix - and I think the screen looks great (looks PRO!). Now, what sort or type of "fiberglass" were you talking about using if you had to do it again please?
Thanks in advance,
g......................
Old Sep 2, 2009 | 04:11 PM
ernesto's Avatar
ernesto
Just regular window screen material.. I had metal at home, so if was "free", fiberglass would be easier to work with.
Here is a sample from Home Depot, you can probably get a smaller size for less money.
Old Nov 22, 2009 | 06:00 PM
julez's Avatar
julez
Sorry to bump this but I remembered this thread while working on my mini today and I did have some fiberglass screen material...
How does the vent pop out? I could feel the tabs in the back but they didn't seem to move and I didn't want to break them.
Thanks!
Old Nov 24, 2009 | 04:34 AM
anitan1's Avatar
anitan1
Ernesto,
That screen looks fantastic in there. I need to do the same thing. How do I get those cowl vents off? I tried getting them off this past weekend and couldn't figure it out/didn't want to break anything, so I left it alone. Was gonna look for tips on here (very glad I waited!).
Old Nov 24, 2009 | 04:45 AM
Capt_bj's Avatar
Capt_bj
no special tricks ... just pull
from the front edge as I recall
Old Nov 24, 2009 | 05:47 AM
100percentcotton's Avatar
100percentcotton
The window screen looks great. Gonna have to try this as my foam has fallen completely apart as well
Old Nov 25, 2009 | 03:26 PM
anitan1's Avatar
anitan1
I did the window screen mod this afternoon. It turned out awesome!!
It was raining today when I drove home...the car is dirty...
Attached Thumbnails Pollen Filter Replacement?-vent-screen-mod_0001_xsmall.jpg   Pollen Filter Replacement?-vent-screen-mod_0002_xsmall.jpg
Old Nov 25, 2009 | 04:20 PM
ernesto's Avatar
ernesto
Looking good!!!!
Old Nov 25, 2009 | 04:22 PM
anitan1's Avatar
anitan1
Thanks Ernesto!
Old Jun 10, 2010 | 02:22 PM
illegalprelude's Avatar
illegalprelude
So besides the Home depot trick, where else can I get these from? Dealership has them for $40 a vent. Eek. They do replace the whole unit, not just the foam but still
Old Sep 6, 2011 | 02:57 PM
edgy's Avatar
edgy
Thanks - it took me longer to search for this thread than the actual replacement took. I had the fiberglass window screen material on hand. It's a much better answer than that fragile foam stuff that came with the vents.
Gracias, amigo!
Old Sep 6, 2011 | 05:42 PM
Tom D's Avatar
Tom D
FWIW, I replaced mine long ago with the new version, no screen to worry about . I have not missed the screen at all, just change the cabin air filter occasionally.
Old Sep 20, 2011 | 05:42 PM
mephikristiles's Avatar
mephikristiles
Thanks, guys! A few bucks and a few minutes of effort--worked like a charm. Looks much nicer, now.
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
