Battery terminal
Old 07-20-2018, 05:35 PM
eh0013's Avatar
eh0013
eh0013 is offline
Battery terminal
New '88 classic. How does one connect a new battery with terminals that have a screw on top of it. I've never seen it before and the pep boys guy was puzzled too. It's easy enough to get a replacement negative (-) wire/connector but i still have to deal with the positive. Even the screw on top is so short that it barely reaches the battery pole. Does one put a hole on the terminal? Do I need a longer screw? There's no way to tighten the connector onto the battery terminal otherwise . So sorry if this has been asked before....I did try to search. Thank you.
Old 07-22-2018, 09:15 AM
BRGPA's Avatar
BRGPA
BRGPA is offline
Can you exchange the battery for the right style? If not I thought I saw an adapter at Advance Auto that could handle the issue.
Old 07-24-2018, 02:00 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
early mini had a lead cast cap that was screwed onto the Batt terminal these can be cut or melted off and a modern terminal fitted
Old 07-27-2018, 09:17 AM
eh0013's Avatar
eh0013
eh0013 is offline
Thank you so much for your replies. I guess they're called "helmet type", appropriately so, and they're supposed to have self-tapping screws on top...as I said, the ones on mine seemed too short. I'll check advance auto and/or other options.
Old 07-27-2018, 10:42 AM
mk1leg's Avatar
mk1leg
mk1leg is offline
as said above
eh0013 (07-27-2018)
Old 07-27-2018, 11:37 AM
MVPeters's Avatar
MVPeters
MVPeters is offline
You could try a slightly longer or fatter self-tapping screw for now.
But in reality the helmets were never a very reliable connection - you're much better off with a clamp type terminal.
eh0013 (07-27-2018)
Old 07-29-2018, 02:06 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
I learn something new about Mini all the time ... never heard of or saw this 'screw' type cable connector but did some digging and shazam there it is.
Assuming you have some cable length to play with I'd cut off that connector and replace with a clamp type available at any parts store for a few dollars. When my car arrived from UK, a 79 I got back in 04, it already had a standard clamp type
eh0013 (08-02-2018)
frindle
04-15-2017 12:42 AM
pimpedout97x
09-16-2008 06:17 AM
Sullivan'sDaddy
09-29-2006 03:14 PM
chollo9
12-31-2004 05:08 PM
Quick Reply: Battery terminal
