R60 Doesn't seem to build very quick.
Old Apr 12, 2020 | 01:26 PM
CountryMouse's Avatar
CountryMouse
My wife's car has been running a bit down on.power and trying to track it down. Only reaches 8 psi boost and that is after a long pull and quick gear change and then may hit 8 psi. Just looking where to start looking for issues.
Old Apr 14, 2020 | 07:09 AM
facundo escudero's Avatar
facundo escudero
Have you tried looking at the intake piping after the turbo and trough the intercooler up to the throttle body for leaks. The loss in boost could be from loose connections as that piping is only held on by hose clamp like clamps
Old Apr 15, 2020 | 07:52 PM
CountryMouse
I have smoke and pressure tested every line and hose on the car. Not a single leak anywhere, I was hoping to find something like that.
Old Apr 16, 2020 | 03:58 AM
Jason Cornelius's Avatar
Jason Cornelius
If you have checked for boost leaks, have you checked your divertor valve? There was a member that just blew his out a few weeks ago.
Old Apr 16, 2020 | 09:24 PM
CountryMouse
Pressure side leaks, and the diverter valve is new 300 miles ago.
Old Apr 17, 2020 | 03:31 AM
facundo escudero
If you haven't already I'd invest in a OBD2 reader from Amazon, they're cheap and have helped me a lot with my mini. Aside from that I'm not really sure what else it could be, maybe the waste gate on the turbo is faulty? If I remember correctly, it supposed to diver the exhaust fumes so the turbo isn't over spinning.
Old Apr 17, 2020 | 10:01 AM
2014 MC's Avatar
2014 MC
You're saying the pressure/boost side has leaks?
Daniel Carulli
Sep 30, 2019 08:12 PM
whrisk
SCCA Solo and ProSolo
May 16, 2018 05:07 AM
ebowling
May 6, 2016 03:11 PM
odieman23
Oct 14, 2015 05:24 PM
SooperCuperErik
May 3, 2011 12:58 PM
