Hello everyone!
Hello!
My name is Pat and I’m the proud new owner of an 05 R52 (base). I paid $1400 for it with no 5th gear and an inoperable convertible top. So, I fabricated a replacement for the cracked plastic link on both latches so that the cables could sense properly, and proceeded to familiarize myself with the Getrag 5 speeds. The pictures should tell you the rest. https://cimg0.ibsrv.net/gimg/www.nor...3b7764c52.jpeg https://cimg2.ibsrv.net/gimg/www.nor...a193271d2.jpeg https://cimg8.ibsrv.net/gimg/www.nor...0d3310036.jpeg https://cimg0.ibsrv.net/gimg/www.nor...11d436d7f.jpeg https://cimg1.ibsrv.net/gimg/www.nor...c613a7ba3.jpeg |
https://cimg0.ibsrv.net/gimg/www.nor...7812174e8.jpeg
https://cimg2.ibsrv.net/gimg/www.nor...7fcfd021e.jpeg https://cimg4.ibsrv.net/gimg/www.nor...0c76be7c9.jpeg https://cimg7.ibsrv.net/gimg/www.nor...cd853ac41.jpeg https://cimg0.ibsrv.net/gimg/www.nor...8afe55d02.jpeg https://cimg4.ibsrv.net/gimg/www.nor...78b426be6.jpeg Here you can see the link reinstalled as well as the parts transmission I picked up from a wrecked mini |
https://cimg5.ibsrv.net/gimg/www.nor...3aee3eb3c.jpeg
https://cimg8.ibsrv.net/gimg/www.nor...b22a02afe.jpeg https://cimg4.ibsrv.net/gimg/www.nor...d22925b81.jpeg https://cimg9.ibsrv.net/gimg/www.nor...6a4bd4719.jpeg https://cimg4.ibsrv.net/gimg/www.nor...d77a64dce.jpeg https://cimg8.ibsrv.net/gimg/www.nor...19f8bee1c.jpeg https://cimg4.ibsrv.net/gimg/www.nor...d6e0bcadc.jpeg https://cimg7.ibsrv.net/gimg/www.nor...bd01b2b98.jpeg https://cimg1.ibsrv.net/gimg/www.nor...1452ddb7a.jpeg https://cimg4.ibsrv.net/gimg/www.nor...f915902f1.jpeg https://cimg8.ibsrv.net/gimg/www.nor...dda218ab0.jpeg And here is the 2nd transmission I picked up, was making noise, but had good cases. I built one out of the two along with new synchros, bearings, and seals |
https://cimg8.ibsrv.net/gimg/www.nor...434a3e83d.jpeg
https://cimg0.ibsrv.net/gimg/www.nor...d24c92c20.jpeg https://cimg2.ibsrv.net/gimg/www.nor...2db5061f7.jpeg https://cimg5.ibsrv.net/gimg/www.nor...fed175611.jpeg https://cimg7.ibsrv.net/gimg/www.nor...04b72ef1c.jpeg https://cimg9.ibsrv.net/gimg/www.nor...bf1742194.jpeg https://cimg3.ibsrv.net/gimg/www.nor...1991f3313.jpeg https://cimg1.ibsrv.net/gimg/www.nor...b4401e95d.jpeg https://cimg5.ibsrv.net/gimg/www.nor...bee25edff.jpeg https://cimg0.ibsrv.net/gimg/www.nor...5b782ba7d.jpeg Removal and Installation, it had a stage 2 clutch and solid flywheel already from what i was told...idk about the flywheel but was happy to save the money on the clutch |
https://cimg8.ibsrv.net/gimg/www.nor...248508d03.jpeg
https://cimg0.ibsrv.net/gimg/www.nor...999c1b029.jpeg https://cimg5.ibsrv.net/gimg/www.nor...6c24c682d.jpeg https://cimg9.ibsrv.net/gimg/www.nor...86b3763fb.jpeg https://cimg0.ibsrv.net/gimg/www.nor...b26894706.jpeg https://cimg2.ibsrv.net/gimg/www.nor...7278bfbd4.jpeg https://cimg4.ibsrv.net/gimg/www.nor...9f68a8f5c.jpeg https://cimg5.ibsrv.net/gimg/www.nor...45d345c1b.jpeg New outer ball joints and cv shafts since the old ones were wrecked by the idiot that “repaired” the old transmission. Nearest I can tell, the old trans had a carrier bearing let loose |
https://cimg9.ibsrv.net/gimg/www.nor...a09b7546d.jpeg
https://cimg1.ibsrv.net/gimg/www.nor...5feeca4f4.jpeg https://cimg2.ibsrv.net/gimg/www.nor...325944fc4.jpeg https://cimg7.ibsrv.net/gimg/www.nor...779831862.jpeg https://cimg9.ibsrv.net/gimg/www.nor...bf919579d.jpeg https://cimg1.ibsrv.net/gimg/www.nor...b0edca697.jpeg https://cimg3.ibsrv.net/gimg/www.nor...078085bc6.jpeg https://cimg9.ibsrv.net/gimg/www.nor...5641ff3d1.jpeg https://cimg0.ibsrv.net/gimg/www.nor...0576588f0.jpeg https://cimg2.ibsrv.net/gimg/www.nor...d2db5c12f.jpeg https://cimg4.ibsrv.net/gimg/www.nor...86e77c3c1.jpeg https://cimg0.ibsrv.net/gimg/www.nor...caa06a14e.jpeg https://cimg2.ibsrv.net/gimg/www.nor...73d7a642b.jpeg Final modifications. The cigarette lighter didn’t work, so I replaced it with a dual 5.0 amp output usb charger with voltage and amperage display, and installed an AUX input kit. I used a spare switch hole since I don’t want to have to open the glovebox if I don’t need to. |
Welcome to the forum. You do extremely impressive work. I was disappointed to see the license plates on the cars. I was hoping you weren't too far away.
Originally Posted by miniCPA
(Post 4478174)
This has been a fun project |
Hi and welcome to NAM!
If you have any trouble with the five speed in the future, look at moving up to the six speed! The trans oil should be a full synthetic, like Redline MTL Congrats on your nice work! |
Originally Posted by ItsmeWayne
(Post 4478258)
If you have any trouble with the five speed in the future, look at moving up to the six speed! The trans oil should be a full synthetic, like Redline MTL Congrats on your nice work! looked into the 6 speed and just didn’t want to invest, and the tighter ratios actually result in worse economy from what I’ve read... |
Welcome and congrats on bringing it back to life, well done.
Originally Posted by OhFiveR52
(Post 4478277)
Thanks. I’m running valvoline MTL full synthetic.
looked into the 6 speed and just didn’t want to invest, and the tighter ratios actually result in worse economy from what I’ve read... Just a thought! |
(Post 4478318)
The 6 speed is known to be more robust. I have a 210 HP 06 R53 JCW and I am getting around 30 MPG (this isn't too bad) , but the Justa Mini models get way better!
Just a thought! This transmission will last me quite some time I’m sure. I’m well past the years of doing burnouts and seeing how fast 0-60 is. More of a “ get to speed and set cruise” kind of guy now lol. |
(Post 4478309)
I get what you are saying!
Do you know why the cases blew out? That is a fairly bad break, so I am guessing something jammed in the gears and blew the case. So what did you find? I drive mine pretty easy, until I get it into the twisties! Then things change for me! LOL It is just so fun to push this little car! Enjoy yours, as I know you will! |
(Post 4478425)
Do you know why the cases blew out? That is a fairly bad break, so I am guessing something jammed in the gears and blew the case. So what did you find? I drive mine pretty easy, until I get it into the twisties! Then things change for me! LOL It is just so fun to push this little car! Enjoy yours, as I know you will! Well, the carrier bearing for the bell housing side that was “repaired” had been replaced along with the race, so I’d have to assume that that’s to blame. Especially since the carrier itself is beat up where it made contact with the case. im sure debris from the failing 5th gear shift fork had something to do with it as well |
For your original, turn or not question...i have turned many of these and i would be surprised if you need to take off more than .003 to straighten that one out
