2014 Paceman Roof Rail Installation
I am taking delivery of a 2014 JCW Paceman this week. I would like the roof rails added (outside 2 only) however the tech is telling me there is no installation template and the headliner must be dropped for installation?? Please comment if you have learned answers. "I don't know" or "I am not sure" won't help me. Thanks for your time, Motor On!
Well I can tell you that is added they will have to drill and bolt it on. Also looks to be different colors available. You are doing this to add the base bars roof rack ?
http://www.realoem.com/bmw/diagrams/r/r/321.png Which you would have to take the headliner out. Have not heard of anyone adding rails. Most are just ordered that way, if they want it. Were you not able to order it or did you buy your MINI off the lot. Thanks |
Bought the JCW Paceman from a Rhode Island dealer new through my dealer in Knoxville. I simply like the look of the rails, I think they compliment the Panoramic Sun Roof. I don't intend to use the rails, just decoration. Thanks for your response.
Oh , ok. Just wanted to make sure. Well if you do like to haul with it people have added the Roof Rack for utility. Good luck with the install, hope it turn out very nice.
http://www.realoem.com/bmw/diagrams/t/p/515.png Roof Rack Base Bars - Cross Member part # 82712343902 http://www.ecstuning.com/Search/SiteSearch/82712343902/ https://cimg8.ibsrv.net/gimg/www.nor...63d7fbd3fa.jpg No roof rails: http://s1.cdn.autoevolution.com/imag...os-53972_1.jpg VS. https://file.kbb.com/kbb/images/cont...c1-600-001.jpg Gives it a little more definition on the top. |
How about a line on the Chili Red trim pieces on the door panels, dash and console (6 pieces I think)? The dealer tells me that they are available as complete panels which I sincerely doubt!!
You should have the chili red plastic trim panels already with the JCW Paceman , unless something was ordered different ?
http://imganuncios.mitula.net/2013_m...2954720158.jpg Thanks |
Mine is all carbon black, the trim is either a yes or no at original order and in my cars case it was a "NO" order. Of course I would prefer the red and need to find out how to order the 6 trim pieces separately.
Ah makes sense now . Guess what you can get the #2 , #3 and #4 now. These were not available a couple months ago. Currently they will have to come from Germany. These are for people that already have a trim piece already there, like black , dark anthracite... etc. Think this will not work with the blank piece dashes ( just an indentation and no mount )( on others without that option ) .
http://www.realoem.com/bmw/diagrams/n/r/509.png Countryman and Paceman. #2 Chili red Part # 51459809557 http://www.ecstuning.com/Search/SiteSearch/51459809557/ #3 Chili red part # 51459809562 http://www.ecstuning.com/Search/SiteSearch/51459809562/ #4 Chili red part # 51459809567 http://www.ecstuning.com/Search/SiteSearch/51459809567/ ------------------------------------------------------------------ http://www.realoem.com/bmw/diagrams/w/n/489.png These center pieces have been out for a bit. Fits Countryman and Paceman models. #16 JCW version http://www.ecstuning.com/Search/SiteSearch/51459813353/ http://c1552172.r72.cf0.rackcdn.com/530165_x600.jpg ------------------------------------------------------------ http://www.realoem.com/bmw/diagrams/b/g/477.png It looks like you have to get the whole door card on the Paceman. #1. Also there is a split year in 9/2013 and I will have to have your last 7 digits of your Vin, to tell what option you have , color line, checked, etc . Looks like a bunch of options. Or a pic. Thanks |
Just bumping this thread for anyone else looking to add roof rails. I did it last night and wasn't really all that difficult. I used the installation guide for the F56 retrofit kit as a template since it was basically the same setup. I didn't have a drill guide though so I just installed the "alignment element" and used that as a guide. The holes in the roof structure are clearly defined and there is no interference from the air bag system. The biggest issue was working around the headliner since I couldn't remove it from the car.
Nice , do you have pics, this great that it worked for you. :)
http://www.realoem.com/bmw/enUS/show...diagId=51_8037 Part #'s here ^^ Just need the left and right rail , then 8 x 51139811335 & 8 x 07143456364 |
Originally Posted by xr7kid
(Post 4144457)
xr7kid will hopefully post up the DIY. If you need the parts they are linked above.
(Post 4144466)
http://www.realoem.com/bmw/enUS/show...diagId=51_8037 Part #'s here ^^ Just need the left and right rail , then 8 x 51139811335 & 8 x 07143456364 could i get a quote for the rails in black, the alignment tool and the necessary hardware? you can PM me the quote |
Hello,
You can just add the part number to cart, then your zip and it will calculate the shipping. What rail color are you looking at, silver, gray, or black? Thanks Mike |
black
Black version:
Left Rail - Black https://www.ecstuning.com/Search/SiteSearch/51139812897/ Right Rail - Black https://www.ecstuning.com/Search/SiteSearch/51139812898/ Add to cart and make sure the two pieces of hardware are Qty 8 each 51139811335 and 07143456364 Alignment Element https://www.ecstuning.com/Search/SiteSearch/51139811335/ and Hex nut https://www.ecstuning.com/b-genuine-mini-parts/hex-nut/07143456364~oem/ Thanks |
