Mini Cooper Billy Club Shift Knob
Mini Cooper Billy Club Shift ****
Having both hands on the wheel is a critical element for maximum car control. In the amount of time it takes to shift races can be won or lost. Moving the shift **** closer to the steering wheel reduces shift time and increases car control. The Billy Club Shift **** by Sneed4Speed accomplishes this by increasing the height of the shift **** in a functional, clean, weighted design. When more grip is needed, the Billy Club Pro provides it, giving you extra traction with its diamond grip pattern, so your hand stays planted. All Billy Club Shift ***** are made in the USA out of heat and abrasion resistant Delrin plastics, meaning Billy Clubs won’t burn your hand when they sit in the sun and won't scratch from use. Speed Shift ***** are direct fit and install exactly the same as the stock OEM shift **** they replace.
NO adapter or insert needed!
Spec Sheet:
Height: 5.75in.
Width: 1.75in.
Weight: 9.90oz.
Color: Black
Finishes:
Delrin: Smooth or Knurled
Billet Aluminum: Smooth or Knurled
Spec Sheet:
Height: 5.75in.
Width: 1.75in.
Weight: 9.90oz.
Color: Black
Finishes:
