Suspension F56 rear lower control arms install
Old 12-08-2016, 05:24 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
DarkMiniCooperS is offline
Hi,
Anyone knows how long it takes to install 2 rear lower control arms on a 2016 Cooper S?
I would guess it's not a hard job?
Old 12-08-2016, 06:27 AM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
I'll guesstimate about an hour. I had mine done the same time as RSB, end links, springs, and brakes. Not a hard job since mine (NM Engineering) were set to factory specs when I got them and didn't require adjustment. Give your dealer a call and ask for the install price. They can give you the time needed per their labor book. Wish I could be more help.
Old 12-08-2016, 03:03 PM
DarkMiniCooperS
Thanks for the input
I just installed NM lowering springs and the rear camber is all messed up, especially the passenger side wheel... It has a 3deg angle so I got adjustable control arms to fix that... Weird thing is that the driver side wheel is ok...
Beside that camber issue, the NM lowering springs is perfect and a lot more aggressive than I thought when ordering them...
Old 01-01-2017, 01:54 PM
DarkMiniCooperS
Just as an info for future searches:
It took my local shop roughly 1 hour, and was very easy...
Old 01-03-2017, 01:26 PM
J_L's Avatar
J_L
J_L is offline
What's the benefit of the arms? Just for better alignment, or is there a difference in handling or at least feel? Thanks.
Old 01-04-2017, 12:47 PM
DarkMiniCooperS
Just for alognment...
OEM rear control arms are not adjustable.
