MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Stock Problems/Issues
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
39 Replies, 900 Views
Advertisement
Thread Tools Search this Thread
  #26
Old 07-13-2007, 05:26 AM
erickvonzipper's Avatar
erickvonzipper erickvonzipper is offline
Send a message via AIM to erickvonzipper
Gallery
Quote:
Originally Posted by h20baby View Post
Although it is unknown whether the formula contains fish oil, material safety data sheets for the product show that the main ingredient is Stoddard solvent, not fish oil.[2] WD-40 is, however, used by some sea fishermen as an added scent when fishing with bait.
Yes, WD40 does smell delicious. 'It's a floor wax.' 'It's a dessert topping.' 'It's a floor wax.' 'It's a dessert topping.' 'It's a floor wax and a dessert topping!'
Zip
<a href=http://www.northamericanmotoring.com/forums/signaturepics/sigpic16898_13.gif target=_blank>http://www.northamericanmotoring.com...ic16898_13.gif</a>
www.usminiclub.com Obie: my '05 MINI Cooper - Jet Black, Premium and Sport packages, chrome side vents with white/clear repeaters, M7 STPs, K&N 57i intake, Megan Racing MINI Cooper cat-back exhaust, TSW engine damper, Alta 19mm anti-sway bar, Ian Cull anti-nanny circuit.
  #27
Old 07-26-2007, 07:43 AM
saturn5rocket saturn5rocket is offline
Gallery
Quote:
Originally Posted by BG'sMC View Post
Interesting to read this. I noticed on my 03 that the right side of the hatch was sticking out about 1/4" beyond the body. The Mini Service Tech told me the hinges had siezed a bit and bent. I quit using the hatch and watched the gap grow to about 1" without ever opening the hatch. Anyone ever seen this, or any ideas on what happened?
I had the same problem with my 02 MC. I watched the gap grow to the point where the hatch wouldn't lock. When I tried to adjust the hinges, the drivers side hinge snaped. Fortunately it was covered under warranty.
Wes J.
2002 MINI Cooper
93 H Stock
  #28
Old 07-27-2007, 09:18 PM
StillK StillK is offline
Gallery
We are talking the hinges at the top near the roof not the latch near the bumper right? I checked mine (2003 MC)
and could see no rust - living where I do everything rusts with the amount of salt they use in the winter. When they rust does the hatch bind? Mine seems to open and close with no problems.
  #29
Old 09-25-2007, 05:58 AM
MIKE PREDINA MIKE PREDINA is offline
Gallery
Good info on this thread. My left hinge broke at 94,000 miles (Car bought in July 2005). The design is really pretty poor. The hinge is a piece of sheet metal wrapped around a steel pin. When rust collects between the pin and the sheet metal hinge, the sheet metal no longer pivots on the pin but instead, it stays put, so when you open the hatch, the sheet metal part of the hinge bends back and forth until eventually it breaks, which it did in my case. I've owned hundreds of cars in my life and I've NEVER replaced a trunk hinge. Stay tuned.
05 MC Astro Black/White, CVT, Premium Pack, Black-N-Tan Leather, Sirius, etc.
He who dies with the most toys is just as dead as any other dead guy. Mike Predina
  #30
Old 10-06-2007, 11:24 AM
Gallery
HATCH HINGE PROBLEM
Just to follow up on the hatch hinge problem with my '05 MINI, here's the latest. As previously mentioned, the hinge is a poor design, with a sheet metal hinge wrapped around a steel pin. Rust builds up between the pin and the sheet metal hinge, the hinge then becomes solid and the sheet metal part flexes back and forth until it breaks. The good news-repaired under warranty. Once again the guys at Classic MINI came through and kept my MINI running along at a high rate of speed. Thanks again to Joey1320 for the heads up on this problem. Remember, my car is just over 2 years old and had this hinge failure. Oil your hinges on a regular basis. They're really up in an enclosed area so not easy to oil, (which makes you wonder how they got rusted) but you definitely do want them oiled. Happy motoring!
  #31
Old 10-20-2007, 12:10 AM
D0HC D0HC is offline
Gallery
Does anyone know what is covered/done by the dealer to fix this problem? Or do they just replace it with the same sort of hinge set up? Thanks.
  #32
Old 10-20-2007, 06:20 AM
Gallery
Quote:
I looked at-but did not closely examine-the old hinges and the new ones and they looked about the same. I'm sure that if they are properly oiled the new ones will be OK, but, as previously mentioned-IT'S A DUMB DESIGN. Also, I didn't see anything in the manual about the need to oil the hinges, and chances are the dealer didn't do it when you took your baby in for general serevice. If you can't get them fixed under warranty-and BMWMINI should honor that-they cost a little over 20 bucks apiece-replace them both. The service Tigers at Classic MINI replaced mine in about a half hour or so. You have to drop the headliner to get at the hinge to body mounting bolts, but the rest is easy. Two (maybe three) guys to mount the hatch back on the new hinges. Happy motoring!
  #33
Old 09-30-2008, 01:29 PM
jayski jayski is offline
Gallery
Hatch Hinges
Just had to replace the hinges on my 03 Cooper.
Was having problems closing the hatch - seemed to be out of alignment. Took it to Fairfield Mini in Ct and was told that this is a common problem with Mini's - and that I would be better off taking it to a body shop as they would be sending it out to a shop to repair.
The hinges themselves cost only $31 - but the labor involved was 4 hours - got the pix to show the steps that the shop took.
Contacted Mini customer support as I felt that this was a design flaw as I have owned all sorts of cars, 36 to be specific, and never have had a hinge fail!
I was told by Mini USA that this is attributable to normal wear and tear.
Not very happy.
jayski
03 Cooper
VR?VR
  #34
Old 10-28-2008, 04:32 PM
oats15 oats15 is offline
Gallery
I'm not trying to bring back old threads, but I have had the same problem. I have an 06 with 50k on it. One hinge broke and it cause the other to bend and broke a hydaulic cylinder. I was not very happy.
  #35
Old 06-26-2009, 07:24 PM
krisdock krisdock is offline
Gallery
The rear hatch hinge just broke on my '03 mini (50,000 miles, no more warranty). I was in the grocery store parking lot holding my hatch, just flabbergasted. In general, I LOVE my mini, but it is LAME that this wasn't a recall if it happens a lot.
Any advice on a do-it-yourself fix? Posts of the photos from the shop work?
  #36
Old 06-27-2009, 02:20 AM
Cadenza Cadenza is offline
Gallery
Ah... this is funny. You should have taken a photo and send it to MINI.
  #37
Old 08-12-2009, 04:37 PM
LizzyBobio's Avatar
LizzyBobio LizzyBobio is offline
Gallery
My hinge on my 06 just broke! Should have read this thread earlier
My Cooking Site
  #38
Old 08-12-2009, 05:46 PM
bratling's Avatar
bratling bratling is offline
Gallery
Quote:
eeek!
note to self: lube my hinges!
i'm sorry to hear yours broke, but your update to this thread is what brought the thread to my attention ... so thanks for that, you may save me a hinge someday!
((as much as i hate to admit it, i'm sometimes wrong. corrections are welcome!))
  #39
Old 08-12-2009, 08:44 PM
TSR53's Avatar
TSR53 TSR53 is offline
Gallery
In case you missed my first posting and good for a bump...
The proper lubricant to use is Würth HHS 2000.
I'm going out in the garage and spray some more on the hinge again!
Original Owner's Club Designer .:: Cheers, Thompson ::. CROC #78
MINI Challenge Germany report //tsrennsport.com
  #40
Old 08-13-2009, 04:30 PM
LizzyBobio's Avatar
Gallery
Quote:
Originally Posted by bratling View Post
eeek!
Glad to help Dealer service said "What is it with these lately?!"
My Cooking Site
  #41
Old 08-14-2009, 04:35 PM
Capt_bj Capt_bj is offline
Gallery
02 traded recently ... 0ver 80,000 miles .. bought off the lot in 02
no hinge problems
never lubed 'em
sorry
Capt BJ '79; 02 S {02 - 09}, 07 S
  #42
Old 08-20-2009, 09:29 PM
LeftyClayJar LeftyClayJar is offline
Gallery
I was having a little trouble with my boot lately, but I thought it was just a weak hydraulic arm or something. But then yesterday the right hinge on my 05 MC snapped in two, when I was trying to shut the door. I looked like an idiot wrestling against the hydraulics to get the darn thing closed. I just found the hinge part number and am going to try to have a local guy fix it up for me. I feel a little better knowing this isn't an uncommon problem - I've been having a string of bad luck lately, mostly not MINI-related.
  #43
Old 08-23-2010, 07:26 AM
autoxgod autoxgod is offline
Gallery
Saved $700 in hinge replacement-DIY EZ
OK, so my hinge on the hatch broke on my 05' R50. Brought it to Knauz Mini and was told it's $700 to replace them, $600 not painted.
So I bought a pair of hinges from the Penske website, took a look at the headliner, gave it a slight pull and found the inner nuts where the hinges are mounted. It's a simple 13mm socket on a small ratchet for the inside nut and a star wrench for the outside bolt, I replaced them in about 15 minutes. Saved $700...
Jim
  #44
Old 08-23-2010, 12:02 PM
Crashton's Avatar
Crashton Crashton is offline
Gallery
autox thanks for the how to. I'm hoping never to have to replace mine, but it is great to know that it is not a bad job.
  #45
Old 11-16-2010, 05:01 PM
laureleb laureleb is offline
Gallery
BOTH boot hinges broken!
I love my '06 dearly, but.... this Spring the left boot hinge broke, and also broke a strip of plastic along the window in the process. Cost $800+ to have this fixed. NOW the right hinge is bent, and I'm on my way to having it replaced as well. I contacted our dealership (have bought 2 minis there) as well as MiniUSA. Not a happy motorer - I think the company should have replaced this as it's definitely a defect, and mine is no longer under warranty.
  #46
Old 11-20-2010, 09:24 AM
norm03s's Avatar
norm03s norm03s is offline
Gallery
Checking mine in 5 min., using white grease in a spray can.
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
George Carlin
You can follow me if you want but it might hurt.
  #47
Old 11-20-2010, 11:26 AM
ellcapitan's Avatar
ellcapitan ellcapitan is offline
Gallery
Great, yet another "common MINI problem"! Where do you get that "Wurth" stuff?
The Ultimate Mister Magoo Car.
  #48
Old 12-29-2010, 05:56 AM
TSR53's Avatar
Gallery
Quote:
Do a google search for "Wurth HHS 2000". And then click the shopping results. Can be purchased through Amazon.com. This German grease is by far the BEST solution for preventative maintenance on these hinges. I'm going out this morning to grease mine again!
http://www.amazon.com/Wurth-HHS-2000.../dp/B0002XRDLE
  #49
Old 12-29-2010, 09:22 AM
ellcapitan's Avatar
Gallery
Thanks for the link. Just ordered a can. Pricey stuff!!
  #50
Old 12-29-2010, 10:05 AM
Crashton's Avatar
Gallery
Thanks for the link Thompson. Just ordered a can for the garage shelf. Much cheaper than replacing hatch hinges.....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
