Got a Puncture with conventional tires
Old Oct 21, 2009 | 08:55 AM
Driv3r's Avatar
Driv3r
I got a puncture with conventional tires, but my TPMS did not trigger? is there something wrong with it?
Old Oct 21, 2009 | 09:31 AM
STLMINI's Avatar
STLMINI
Did the puncture cause the tire to lose air?
Old Oct 21, 2009 | 10:40 AM
Driv3r's Avatar
Driv3r
yes it did, it went almost completely flat. There was a hole in the side wall of tire.
Q: Why dont tire shops repair(put a plug) a hole on sidewalls of tires?? they say a new tire is needed. Lucky for me i had a new tire!
Old Oct 21, 2009 | 11:37 AM
cristo's Avatar
cristo
Alliance Member
Can't plug a hole in the sidewall. Everyone agrees about that.
Old Oct 21, 2009 | 12:58 PM
Driv3r's Avatar
Driv3r
im a newbie.. why cant you?
Old Oct 21, 2009 | 02:01 PM
ozhead's Avatar
ozhead
As I understand it (and could be wrong), a hole in the sidewall affects the structural integrity of the tire.
Old Oct 21, 2009 | 02:08 PM
Capt_bj's Avatar
Capt_bj
I'm not sure but I believe it has to do with the fact that the sidewall is designed to flex a lot and there isn't nearly as much strength in the sidewall as compared to the main tread surface.
I've heard it said that it is "law" but absolutely can't confirm that but can confirm that no reputable tire repair will plug or patch a sidewall and usually not within 1/2 inch of the edge of the tread.
found this on a National Highway Traffic Safety Administration page (part of DOT) Punctures through the tread can be repaired if they are not too large, but punctures to the sidewall should not be repaired. Not exactly a stern rule but a policy statement anyway....
And then there's some additional reading
http://www.retread.org/PDF/Rolwing.pdf
Old Oct 21, 2009 | 02:39 PM
Gromit801's Avatar
Gromit801
In CA, by law, you cannot repair a hole in the sidewall. That's gospel. The sidewall withstands the most pressure when the weight of the car is upon it.
Old Oct 21, 2009 | 03:09 PM
Capt_bj's Avatar
Capt_bj
can you provide the statute???? Quote the regulation???? Who is tasked with enforcement???
Old Oct 21, 2009 | 04:07 PM
Gromit801's Avatar
Gromit801
Why are you so excited??? I'm looking for it??? When I worked in a repair shop we were forbidden to repair sidewalls???
Old Oct 21, 2009 | 04:15 PM
herbie hind's Avatar
herbie hind
it's a tire conspiracy!!! must be buschs' fault . side walls if i remember are 2 ply and under tread is 4 ply . when you tear or get a hole in side wall ; the tire will quickly degrade . and rip apart and kill everyone in your vicinity when you roll and flip into oncoming traffic;but a plug would be cheaper .
Old Oct 21, 2009 | 06:31 PM
Some Guy's Avatar
Some Guy
What year is your mini. The TPMS system in the earlier one works by comparing rotational speed of the tires, the one that is moving faster is the one that is low on pressure. This of course requires you be moving, so if you arent you will not get a light.
Old Oct 22, 2009 | 03:19 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
Sidewall issue
Tire sidewalls are too thin and have too much flexibility in them to allow a proper repair. Any repair to the sidewall will quickly degrade as the sidewall flexes and separates from the repair. A plug in the sidewall would be futile as the rubber is thinnest at the sidewalls and the plug would soon loose adhesion to the sidewall rubber. I always prefer a patch to a plug (in the tread). Plugs are great for getting you to a service station or tire repair shop, but I wouldn't bet the farm on a plug alone; patch it...but I digress.
I would, IMHO, just suck it up and replace the tire.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
PSU 98
Sep 11, 2015 11:20 AM
Ntety
Sep 2, 2015 08:39 PM
