FS:: Forge BOV Kit
Old 05-18-2013, 06:39 AM
11mcsaz's Avatar
11mcsaz
11mcsaz is offline
Forge BOV Kit
Price: $205
Location (Region): West
Includes every thing you would receive if purchased from a retailer.
$205 shipped to your door if you are in the lower 48.
From the website:
Forge Blow off valve for R55, R56, R57, R58, R59, R60 MINI Cooper S turbo. This Forge blow off valve alternative is a fully engineered solution offering both significantly improved reliability as well as valve related boost response. The Forge valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible. Simply put this valve will improve throttle responce and boost control to enhance the drivability and performance of your MINI. This kit is supplied with an additional upgraded spring (colored Yellow) that may be required if the vehicle has had a significant boost increase.
Kit comes with:
electric solenoid
silicone vacuum line
boost port
screws and mounting hardware
Fits 2007-2010 Cooper S R56
Fits 2008-2010 Clubman S R55
Fits 2009-2011 Cabrio S R57
Fits 2009+ JCW Hardtop R56
Fits 2009+ JCW Cabrio R57
Fits 2009+ JCW Clubman R55
Fits 2011+ Cooper S R56
Fits 2011+ Clubman S R55
Fits 2011+ Cabrio S R57
Fits 2011+ Countryman S R60
Fits 2012+ Coupe S R58
Fits 2012+ JCW Coupe R58
Fits 2012+ Roadster S R59
Fits 2012+ JCW Roadster R59
Attached Thumbnails Forge BOV Kit-p1010627.jpg   Forge BOV Kit-wmw_blowoff_valve_500.jpg
Old 05-18-2013, 09:28 PM
miniac78's Avatar
miniac78
miniac78 is offline
Do you still have your BOV? Email ME Nickbocchicchio@gmail.com
Old 05-19-2013, 12:36 PM
miniac78's Avatar
miniac78
miniac78 is offline
Awesome how much we're you looking to get for the arms and the bov if I do them together .. I can get the bov setup from Steve at Forge for 200 brand new . Make me a deal and Ill pull the trigger right away. Ill Paypal for them and they would be shipped to Goodyear, Az which would cut down on shipping cost .Thanks , nick
Old 05-20-2013, 12:42 PM
Fugy's Avatar
Fugy
Fugy is offline
Pmd you~
Old 05-20-2013, 01:06 PM
11mcsaz's Avatar
11mcsaz
11mcsaz is offline
The BOV is sold . . . .
ebowling
90
08-04-2019 09:15 AM
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
MasterShaftner
11-04-2016 09:38 AM
theunlimitedone
08-31-2015 08:17 PM
Mini Cooper r56 Pr
08-12-2015 07:42 PM
Quick Reply: FS:: Forge BOV Kit
