FS:: N14 PCV delete
Old 03-01-2013, 01:37 PM
Miniman s's Avatar
Miniman s
Miniman s is offline
Price: $16
Location (Region): West
Item Condition: Brand New
Sets are still available
  #27
Old 03-07-2013, 09:05 PM
Miniman s's Avatar
Miniman s
I do recommend that you do a carbon clean so that you are keeping clean valves clean because these caps will stop your build up at whatever point your valves were at when installed.
  #28
Old 03-08-2013, 05:53 AM
ScorpionSkins.com's Avatar
ScorpionSkins.com
ScorpionSkins.com is offline
Hello Miniman,
I wanted to thank you again for the purchase of the caps but regrettably had to remove mine. As I messaged you at an earlier point in time, my car was idling very oddly with both caps installed and produced a sound some would consider akin to a knock. There was also an abnormal and abundant amount of "milky" substance building underneath the oil cap after installation. When having placed the rear pcv hose back to stock, the idle returned to normal and the milky substance subsided.
Could this be indicative of issues with my vehicle specifically?
I've read of great results with these caps and haven't found anyone else who has experienced similar issues, so please don't let this prevent you from picking up a set for those potentially interested.
I'd still like to prevent carbon build up and was planning to pay for a media blast cleaning, but I need to find a solution to this issue first. Any advice or guidance would be appreciated.
My car is an early build 2007 r56. I do not have the updated valve cover installed.
  #29
Old 03-08-2013, 11:35 AM
Miniman s's Avatar
Miniman s
The milky substance is moisture and is this a seperate noise from your earlier post? Again the caps with an air intake will allow you to hear the full load breather valve opening and closing. You do have a direct injection motor and it will sound similar to a diesel. I would do a carbon clean and put the caps on you may just be really close to throwing lights due to carbon.
  #30
Old 03-08-2013, 04:40 PM
ScorpionSkins.com
Thank you Miniman.
It was the same noise. I will further look into the issue and see what options I have available after a proper carbon cleaning.
It's been a pleasure to do business with you, however simple the purchase, fully recommended. Cheers.
  #31
Old 03-18-2013, 08:46 AM
Black Sharpie's Avatar
Black Sharpie
Black Sharpie is offline
Would this work inconjunction with a BSH Catch Can. I have the boost port to close the valve, but I think it's leaking and effecting my boost PSI.
Anyone knowlegdgeable here??
  #32
Old 03-18-2013, 11:39 AM
Miniman s's Avatar
Miniman s
This does work with the oil catch can but I'm assuming by your post you also have the boost tap. So what we do is modify the cap with some hose to test for boost loss.
  #33
Old 03-18-2013, 11:48 AM
Black Sharpie
I want to replace the boost tap which is acting like a block with this. I think my boost port block is leaking leading to loss of boost
  #34
Old 03-18-2013, 12:04 PM
Black Sharpie
Is it just a cap to close the opening in the top left of the engine..
  #35
Old 03-18-2013, 12:07 PM
Miniman s's Avatar
Miniman s
You get 2 caps one for the port you described and one for the port at the other end of the PCV hose.
  #36
Old 03-18-2013, 12:13 PM
Black Sharpie
I imagine I would only need to use the one plug...it just connects to the stock tubing right..
  #37
Old 03-18-2013, 12:19 PM
Miniman s's Avatar
Miniman s
It actually completely gets rid of that hose. So you completely remove the PCV hose and use one plug at each end that the hose would plug in at. If you look at the first link I posted it shows that one plug goes on the intake manifold and one attaches to valve cover.
  #38
Old 03-18-2013, 12:34 PM
Black Sharpie
Would a loose PCV blocker affect Boost PSI?
  #39
Old 03-18-2013, 12:40 PM
Miniman s's Avatar
Miniman s
Yes it would
  #40
Old 03-18-2013, 12:41 PM
Black Sharpie
Payment sent
  #41
Old 03-18-2013, 01:20 PM
Black Sharpie
Can anyone with a BSH catch can and these plugs chime in on the best way to set this up
  #42
Old 03-18-2013, 01:37 PM
Miniman s's Avatar
Miniman s
Carey P installed both and posted earlier on this thread you may be able to ask them for a picture. The two parts don't interfere with each other as the plug into different ports.
  #43
Old 03-22-2013, 11:17 PM
Tommy Liveoak's Avatar
Tommy Liveoak
Tommy Liveoak is offline
Still available?
  #44
Old 03-23-2013, 12:04 AM
Miniman s's Avatar
Miniman s
Yes
  #45
Old 03-23-2013, 01:13 PM
Black Sharpie
Got these and installed them today. I think my bsh boost tap was leaking cause I'm hitting 1-3 psi more of boost. I'll exchange feedback once I'm on the pc. Thanks.
Install is painless
  #46
Old 03-23-2013, 04:26 PM
Miniman s's Avatar
Miniman s
Good to hear
  #47
Old 03-30-2013, 08:21 PM
Tommy Liveoak
Miniman (Jerry) Payment sent and PM you. Just checking if it got shipped.
Tommy
  #48
Old 03-31-2013, 10:52 AM
Jcwaggie's Avatar
Jcwaggie
Jcwaggie is offline
Originally Posted by ScorpionSkins.com
Hello Miniman,
the 2007's don't have the check valve on the valve cover. i don't believe.
  #49
Old 04-05-2013, 08:15 PM
Miniman s's Avatar
Miniman s
Multiple sets are still available
  #50
Old 04-19-2013, 10:46 PM
Miniman s's Avatar
Miniman s
With tax returns coming in prevention is the best maintenance do a carbon clean and by a set to stop the problem.
Quick Reply: FS:: N14 PCV delete
