Cooper (non S) Modifications specific to the MINI Cooper (R50).
Engine Damper Impressions (MC)
Old Sep 18, 2006 | 08:32 AM
  #26
agranger's Avatar
agranger
I never felt the rattle or heard any additional vibration until I did a couple days at the track about a week ago. Now I hear a rattle at idle which goes away immediately as soon as a bit of throtle is applied.
I'll be doing the #12 O-ring trick shortly.
Old Sep 18, 2006 | 11:19 AM
  #27
1FSTMINI's Avatar
1FSTMINI
Ok....Ill email them with pix of my bent bracket and bolt.....But where can i get these o-rings from....My parts dept has a kit but is missing that size and we cant order them seperately for some reason.
Old Sep 18, 2006 | 12:26 PM
  #28
agranger's Avatar
agranger
Home Depot has 'em in the plumbing department near the bits and pieces to repair faucets. I got ten #11 o-rings today for $2... My local store was out of the #12... I hope that the 11s work.
Old Sep 18, 2006 | 01:26 PM
  #29
rkw's Avatar
rkw
What exactly is meant here by "o-ring"? I usually think of the term to mean a rubber ring used for a gasket, which doesn't seem the right kind of hardware for mounting an engine damper. Is it supposed to be a #12 flat metal washer?
Old Sep 18, 2006 | 02:34 PM
  #30
1FSTMINI's Avatar
1FSTMINI
There using the rubber o-ring to stop the damper from rocking side to side at the heim joint where it is vibrating.
Old Sep 18, 2006 | 02:42 PM
  #31
rkw's Avatar
rkw
Thanks, I'll give it a try.
edit: Found it discussed in this Metroplex thread.
Old Sep 29, 2006 | 03:58 PM
  #32
minibull2's Avatar
minibull2
From experience ... I changed my motor mounts on my AudiTT. Lots of vibration through the stering wheel only while idoling.
The only thing that stopped the vibration was going back to the stock flywheel. It seems that the aftermarket flywheel wasnt dampered like the stock and was causing undue vibration that were only felt when I changed the flywheel.
MiniBull
Old Oct 1, 2006 | 11:00 AM
  #33
YakiMini's Avatar
YakiMini
I just posted on the Metroplex forum early this morning. I went down to a Fred Meyer and found a little pack of rubber gasket o-rings in their hardward/plumbing department and they did the trick. About $2 is all that I'm out and it was as simple as that!!!!
Old Oct 15, 2006 | 09:13 AM
  #34
Ords's Avatar
Ords
I installed mine yesterday and using the painter's tape trick from OctaneGuy. Took about 15 minutes.
There is a difference to the feel as others described. "Connected" is correct after some spirited driving and I noticed there's no vibration.
Old Oct 30, 2006 | 10:55 PM
  #35
RonP's Avatar
RonP
I have an '03 MC and would like to install one of these, can anyone post a pic or two of the install with the o-ring? I'm not to clear on how the o-rings install.
Old Oct 30, 2006 | 11:24 PM
  #36
rkw's Avatar
rkw
The o-ring mentioned here is specifically for the Texas Speedwerks version of the damper. I suppose that if other dampers rattle, a similar technique may help. The TSW damper is now shipped with o-rings and installation instructions. A photo of the installed o-rings may be seen here.
Old Oct 31, 2006 | 06:22 AM
  #37
JCWGurl's Avatar
JCWGurl
Coordinator :: Manitoba MINI Motoring Club
Originally Posted by scobib
From the SCCA rule book:
"Alternate components which are normally expendable and considered replacement parts (e.g., engine and wheel bearings, seals, gaskets, filters, belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure plates, suspension bushings, drivetrain mounts, etc.) may be used provided they are essentially identical to the standard parts (e.g. have the same type, size, hardness, weight, material etc.), are used in the same location, and provide no performance benefit."
My thought is no, since the engine damper does provide a benefit and is in addition to standard parts... Although arguably NOT in time shaved off from run-to-run (which I tested), the throttle response does improve rather smartly and there's less lag...
There was some debate at our club if this was a legal stock mod (although we run CAC rules/Canadian). It came down to NO for the same reasons as above but that did lead to mch debate as to if it really benefited you on the autox course. 50% say yes/ 50% say no....
Can anyone who has one tell me if it is a worthwhile mod (if you are already in DSP)?
Old Nov 14, 2006 | 10:58 AM
  #38
trackster's Avatar
trackster
What was their responce to the bent bracket? It looks like a good piece and I am interested but would like to know the outcome of your situation.
Old Dec 12, 2006 | 06:50 PM
  #39
Rastven's Avatar
Rastven
Drove to Shoe to have the damper installed as I'm not great with the wrenches yet and it was more than worth it.
Any lurch is gone and it feels like I have more pickup in 1st and the transition to second is way way better.
This has to be, hands down, the best mod available for the MC and I'd recommend it to anyone.
Old Jan 4, 2007 | 12:42 PM
  #40
xtremepsionic's Avatar
xtremepsionic
Just got one installed. On top of all the above reponses, the best part of this mod is that the choppiness/lurging involved in parking lot speeds and traffic jams are gone. The car is much much smoother on/off the throttle at slow speeds in 1st and 2nd gear.
Old Jan 4, 2007 | 12:46 PM
  #41
txwerks's Avatar
txwerks
If people contact us with issues, we solve the problem...
Old Jan 10, 2007 | 07:35 PM
  #42
shooler's Avatar
shooler
I just finished installing my TSW damper. Although I haven't driven with it yet, I will say the components are top notch in appearance and the illustrated instructions were very easy to follow. I can't wait to try it out.
Old Jan 16, 2007 | 11:48 PM
  #43
kurvhugr's Avatar
kurvhugr
I finally installed mine.....took me 6 months to get around to it, but it's finally in there! So far, I'm happy with the changes; they're all improvements in my book. That includes the slight increases in noise and vibration. I count them as aspects of that "connected" feel described by others.
I notice slight additional vibration at idle, and increased sound as well as vibration when accellerating. Not significant, certainly not objectionable, to me.....of course "significant" and "objectionable" are very subjective terms.
A lot of people have tried to describe the effect of these things and it's VERY hard to improve on "connected".....but here's another way to look at it. It doesn't make the car a harsh environment, but it does take it another notch further down the road away from "comfy." I love it, it's like the additional feedback you get from adding a good catback or intake.
IMHO, if you have to worry whether every mod will pass the "significant other" test, you might want to think twice about this one...maybe.
Old Jan 17, 2007 | 09:40 AM
  #44
txwerks's Avatar
txwerks
A big thanks to you for suggestions on instructions...
For all late model peeps out there and GP owners, we've just sent updated drawings to our fabricator with a few tweaks that will make installs even easier...
Old Feb 11, 2007 | 06:02 PM
  #45
Rastven's Avatar
Rastven
I've recently had to pull the LordoftheFlies damper out while my engine mount was getting replaced and I had to spend a week without it due to the crazy northeast cold.
Got it back in yesterday and immediately remembered why I love the damper so much.
People please do yourselves a favour and buy an engine damper from LordoftheFlies. MC drivers will never regret it.
Old Feb 12, 2007 | 12:17 PM
  #46
ProfessorDave's Avatar
ProfessorDave
Mine came recently and my impression is that it had better warm up soon so I can install the darn thing! Seriously, all of these positive impressions are making me impatient to try it out.
Old Feb 13, 2007 | 06:40 PM
  #47
scottbabu's Avatar
scottbabu
Install a damper if you have cvt?
Do dampers only work well with stick shifts? Do you get similar results with a cvt/auto?
Old Feb 14, 2007 | 06:55 AM
  #48
txwerks's Avatar
txwerks
You will get similar results on a cvt and auto!
Old Mar 11, 2007 | 05:01 AM
  #49
ProfessorDave
(this is a duplicate of a post over in the MCS thread, copied here because it relates to an MC install)
Well, it finally warmed up enough here to install the LOTF engine damper. I would have to say that my initial impression is "mildly positive". The "connected" feel that others describe escapes me. However, there is a noticable difference in the lurching between shifts, an improvement that is worth the reasonable price of this mod. I only have a few miles on it, so I'll keep gathering some observations.
I have a couple of things to say about the installation. It is a biotch! To say that things are tight is an understatement. I have a couple of tips that may help others.
*On my MC the bolt in the engine block (holding a clip and wire) was a 16mm, so have an open ended 16mm handy.
*Definitely use the blue masking tape trick to hold the long bolt/bell washer in place.
*I needed to insert/remove the damper into the small space several times to get the length right. It helps if you slide the damper back toward the firewall, then forward when doing this.
*Put the car on jackstands or ramps...your back will thank you!
*On my 03 MC there was a grounding strap and relay in the way of the space where you want to put your hands during the install. I recommend removing these for the installation.
*Shoe is right about taking your time. Forget the 15 min install times you may have seen...for most of us it will take at least that long just to adjust the damper. 30 - 60 minutes is a more realistic start-to-finish time frame.
Now, back for more road testing!
Old Mar 11, 2007 | 08:28 AM
  #50
erickvonzipper's Avatar
erickvonzipper
I got my TSW damper a coupla days ago. Can't wait to get it in and check it out. tswerks, has the bracket-bending issue been resolved on the latest damper kits (I just got mine)?
Zip
