R50/53 Seth's '03 R53 - Maintenance/Mod Log
#26
Went to a Tar Heel MINI meet today at Flow MINI after a wash. Got a little bauble for the antenna:
Didn't manage to get any good pics at the meet and there were no other R53's, but we had a good lunch and I talked to a gentleman who has had 10 MINIs in his time. He now has a 2013 JCW.
I love my car.
Here's some more pics from my driveway today. I like wheel pics
I love my car.
#28
#31
#32
Looks great, perfect name.
#33
Finally got the time to install the auxiliary gauges I received for Christmas last night. It took me and a friend about 6 hours total to install them, but it was well worth it! I'm really pleased with the results.
The official MINI install instructions I found in the MotoringFiles were a great help, though the step that outlined where the ground adapter was to be installed was not correct. I believe the instructions were made for the R50. We ended up routing the ground strap up to the driver side wiper arm base, so it is accessible without having to remove the intake, though we did that initially.
About two hours into the install, it started dumping rain. I forgot I had my windows down and with the battery and toggle bank disconnected, we just had to throw a tarp over her and mop up the rest with some towels.
Project car status!
After the rain, we finished routing the cable to the new drain plug, which is a thermistor for sensing the oil temperature. A little while later we dropped the car off the jacks and set to work splicing a few wires on the inside of the car and getting the mounting frame in place. We tapped into the power feed for the radio and the power feed for the cigarette lighter as per the instructions. Then we hooked the gauges up while we figured out what angle we should set the mounting frame at to test our wiring thus far. Everything worked! Then we just drilled the screwholes for the mounting frame, plugged everything up, and put everything back together. It was a long process, but very rewarding. Neither of us had done anything like this before, so we were both very happy when everything worked the first time through. We finished around midnight, so a good burger and shake from Cook-Out was in order.
Before and after of the interior:
And some new beauty shots:
Before and after install:
Project car status!
#36
#37
What do you mean by plate? The mounting frame? The voltage gauge power feed comes from the cigarette lighter power feed. Both gauges share a ground just outside the firewall on a little stud on the wiper arm base.
#38
#39
Project car status!
Project car status!
#40
Thanks!
#41
#43
http://www.marshallinstruments.com/c...per_gauges.cfm
Pics of set from ECS.
#44
#45
#46
Had the power steering recall performed today. They replaced the pump, fan, and return line. No issues at the dealer. I talked to the rep and he said the pump and fan were automatically replaced, but lines/hardware only got replaced if it was necessary to do so. They were free, but I guess they're a conditional part of the recall. Something to bear in mind. One thing I already miss, however, is the whine the pump makes when turning near the lock. I have always associated that noise with MINIs, honestly kind of sad to see it go.
New pump is just about silent.
The tech also noted a few issues as per the inspection. He noted multiple oil leaks, torn LCA bushings, and torn passenger side engine mounts. I have not confirmed any of these things yet. I don't doubt my oil is leaking as my oil level was a quart low a couple of weeks ago when I installed my gauges from my last oil change in November. I'm not concerned about the engine mounts.
Also, to add to my previous update about the gauges, I remembered we noticed that the halfshaft boots were torn and slinging grease. I do not hear any clicking when I turn sharply, however, so I've only ordered boot replacements and not entirely new halfshaft assemblies. I might order some LCA bushings and do both at the same time. Would you guys recommend I stick with OEM or upgrade to some poly bushings, maybe from Powerflex? How much noise do they add?
#47
#48
Didn't really notice additional noises with the Powerflex, then again, I have both poly engine mounts and transmission inserts. I highly suggest poly for a simple reason: the oem ones will fail again. I've changed mine with Powerflex 6 years ago and they're still doing their job.
#49
I have the TSW upper engine mount, BSH lower engine mount, Powerflex transmission inserts and the Powerflex LCA bushings. I don't like loose things. But the LCA bushings alone won't make it rattle.
#50
Would you recommend the motor mounts you have over the OEM, not considering their longevity?
