R50/53 Compression
My gut is it might be miss calibrated...
If a car runs good, makes good power, and the readings are even...you are good.
Numbers come up in posts literally all over, thats WHY I suggested it is "normal".
I doubt the overrev did anything as it drives and sounds exactly the same as before.
I screwed the compression tester hand tight then proceeded to do 10 seconds of cranking. i even tried cranking it for 15 seconds but the result was the same, no more than 95ish PSI
My R53 that i had last year, albeit with difference equipment, got around 160 PSI all around. Hopefully it's just the autozone tester?
and YES, the car drives fun and idles perfectly and is REALLY QUICK
I was just doing the compression test to see if the car is worth spending more money on(mods).
