R50/53 Finally, Gen1 Power Steering Delete Kit Available Soon!!!!
#101
Use the original Banjo bolts---they allow air to move freely thru the plastic piece. You should have 5 washers according to the web site--instructions there also.
http://www.condorspeedshop.com/colle...teering-delete
#103
#104
#105
#106
Condor Power steering Delete Install Procedures
1. Remove your power steering system. This includes the pump, FL4 100A PS Pump fuse in the engine bay fuse box, lines, and reservoir.
Da_Ghost shared this:
The FL4 100 amp fuse for the power steering is UNDER the fuse box. You need to disconnect the battery, remove the positive cable on the fuse box and the two bolts holding the box, then flip it over and remove the cover. There's 2 or 3 fuses under there, just make sure it's the correct one you're taking out and they are held by torx screws.
2. Turn your rack full lock from one side to the other side 3-4 times. This removes unnecessary fluid.
3. Slide 1 washer onto the smaller banjo bolt. Slide the delete onto the smaller banjo bolt. Now slide 1 washer onto the same smaller banjo bolt. Your delete should be sandwiched between 2 washers on the smaller banjo bolt.
4. Slide 2 washers onto the larger banjo bolt. Slide the larger banjo bolt with the 2 washers onto the delete. Now slide 1 washer onto the larger banjo bolt.. Your delete should be sandwiched between 3 washers on the larger banjo bolt.
5. Install your delete onto your rack by tightening your banjo bolts.
6. It is important to make sure you do not over *tighten it. You do not want to crush the UHMW.
Questions? email us at condorspeedshop@gmail.com
#107
1st unbiased feedback from r34king:
Done. Its a heavy feel. THIS IS NOT FOR EVERYONE. I like the feel. Its very connected to the road. But it does require more work from the driver. On a lo g highway run you don't feel it. If you don't drive long trips or drive mostly in the city you will hate it. I'll upload a few pics later today.
Read more: http://www.*********************/for...#ixzz38aJzpiz2
#109
r34king further rated the kit an improvement over having a dead pump in. On a scale where:
1-dead pump
10-good pump
He rated it 3-4. With all other PSP issues eliminated, I'll take this anytime. I've an aftermarket steering wheel so i could change to a bigger 1 if I opt to. Some can go dorky steering **** route.
Also, I'm awaiting recommended torque spec from condor.
Please post up your reviews of this kit. Thanks!
1-dead pump
10-good pump
#110
#111
#113
#114
The BMW parts chain is a shell of what it was 10 years ago. I'm still of the thoughts that the part will go NLA or there will be such a short run that it will be NLA a few months after the back orders are filled.
#117
#119
We all know what to expect. It's about personal preference or getting used to. I've asked Condor for their relative review of this & their e30 ones. E30 owners who've done this actually prefer delete over having PS.
They also tried to get torque specs but their torque wrench has 24.5ft.lbs which is too high. Guessing it should be in the mid-teens, so please take extra caution & don't over-tighten.
#120
You can't compare the results of an E30 (rear wheel drive) to the Mini. FWD has it's own issues with the drive wheels being steered--torque steer etc. Only people who are using the Mini kit can provide real feedback for this product. I have a kit sitting here, but have yet to install it. My car is strictly for track use and the feedback from other owners (that I trust) that track their Mini's -->not worth it unless your pump is actually toast.
#121
#122
My ps went out yesterday, with the ignition off it would stay on :( heard when that happens it could catch fire lol so i just removed the 100amp fuse and drove to work this morning with the pump off and its bad but its not impossible like some people say it is. Once the delete kit is on and the ps fluid out im sure I'll be happy with it as i dont have $600 for a new pump lol
#124
updated review from r34king:
"Well after 3 weeks with mine in, I can say I love it. Got used to it after a few days and now I wouldn't go back unless I lost an arm. Although parking maneuvers are still tricky."
Read more: http://www.*********************/for...#ixzz3Amlqzmba
#125
updated review from r34king: "Well after 3 weeks with mine in, I can say I love it. Got used to it after a few days and now I wouldn't go back unless I lost an arm. Although parking maneuvers are still tricky." Read more: http://www.*********************/for...#ixzz3Amlqzmba
