R50/53 Stoker's Rebuild Thread
#28
Sprintex SC CARB Edition W/64 mm Pulley (Sitting In My Office)
Thumper TPR-2 Cylinder head With Cam And Cam Sprocket With Ported IM (Arrives Dec 4)
GP Intercooler With That Fancy diverter...
New Chain. New Belt.
"Straight Through" Exhaust With Battery well "Delete".. Not Sure Which One To Get Yet..
New Oil Pump.
550 Injectors.
Air/Fuel Mix Sensor.
Tune By Bytetronic..
Wet Okole seat Covers..
New Oil Pump.
550 Injectors.
We recommend that you install the Sprintex with the current 69mm pulley, put on about 500 miles to break in the new charger. Then install the 64mm with the proper belt, then proceed with the CRM.
Of course, we will send you a "Base 550cc tune for the Sprintex + TPR head" for you to use during the break-in period. All you have to do is flash this into your ECU with the FA-Lite Tuning kit
#29
#30
#33
1984 Birmingham UK. Those Pop's Were Made From Stainless Steel.. It's Still Alive.. In Cannock UK
#34
Stoker, the Sprintex unit comes with the 69mm (CARB Edition); the 64mm will need to be ordered.
#35
#36
#38
#39
Honestly it's all been said, as far as how much I like mine, if you have anything specific or are curious about anything just PM me, I'll be happy to help. Let me know when install time comes around, may be able to give you a few tips, but it's pretty much "as explained" in the instructions & pretty straight forward.
In general you can expect these boost #'s:
69mm = 15+psi
64mm = 17+psi
60mm = 19+psi
I was actually seeing right @ 20psi.
Personally I justified it as being a next step before a full on Turbo only swap, + I had already done most everything else & my M45 W/P gears were toast.
69mm = 15+psi
64mm = 17+psi
60mm = 19+psi
#40
Turn's out, my local "Mini Shop" had a Boria performance exhaust in stock.
So, I got it yesterday and threw it on the car.
Sounds Amazing!! And pretty easy to put on.
In the long run, it will help with the mods I'm gonna do in the next couple of months…
Not sure if i get an HP gain out of it… But it's worth it, for the racket it makes ")
#41
#42
Hey Stoker... I too purchased a set of Spec-D Halo Headlights for my 2007 MCS.
When I pull towards me to "Flash" the brights... the low beams stay on and the brights come on....
When I push the stalk forward to turn on the brights... ALL the light shut off...
The only way to keep the low and high beams on... is to hold the stalk towards me.
Are your lights working properly???
#43
#44
#47
69mm = 15+psi
64mm = 17+psi
60mm = 19+psi
69mm = 15+psi
64mm = 17+psi
60mm = 19+psi
I am still considering going to a Compound Boost setup. Decreasing the boost on the SC and then making it up with a rear mounted turbo setup. But it is something Ive been kicking around for a few years. I love how this Lotus Exige is setup. This would be so much fun in a Gen1 MINI.
#48
#50
You have to check out that owners website as well as some vids on his other projects. I'd love to see this guy get his hands on a MINI R53 and see what he comes up with. Hell I will volunteer my R53 as long as he gives it back.
