Electrical Dash Lights color change... Now my Climate Control display is jacked.
Hey all!!
Before I started the project I read up as much as I could, but I knew there could be issues since none of the threads were of my same model (2010 Clubman) and none had the climate control.
So here is where I am at... You will see a few areas where there is still orange. Those are the areas that use LEDs other than the PLCC size used in many areas. I am in the process of ordering those.
My big problem is the Climate Control Display... It does not display correctly anymore. Obviously I had to disassemble it to change the color, I am hoping I just forgot a step in the reassembly that someone may be familiar with.
Thanks for the help!!
So frustrating... I just changed the last couple of dual color LED's (which don't work well) and went to replace the needle... As I was inserting, it suddenly pushed really far in and now the tach needle doesn't move at all. I tried removing it and only lightly installing and nothing... Do I now need to get a donor tach for the needle motor?
07-16-2020 12:54 PM
Mini'mon
08-16-2015 04:15 PM
2manyhobbies
08-09-2015 06:02 PM
