Electrical Has anyone used the BMWhat app for iPhone to successfully code there car?
#51
#53
I have been using one of these successfully. I was very skeptical at first but I have experienced nothing but success. I no longer use NCS Expert.
It's worth contacting the All developer because he appears to be qute open to making this App better.
I just use a cheap eBay ELM WiFi adapter.
#54
#55
I can get into the FRM and edit light functions... most seem to work, but I suspect some don't because I don't have the hardware (obviously things like angel eyes don't since my car does not have them..)
But I added the double flash, brake force display, added lights on the welcome/unlock function (which is really handy)..
#56
I can get into the FRM and edit light functions... most seem to work, but I suspect some don't because I don't have the hardware (obviously things like angel eyes don't since my car does not have them..) But I added the double flash, brake force display, added lights on the welcome/unlock function (which is really handy)..
#57
I don't believe you can code out that alarm as it would be a safety violation in most countries.
Craven makes the Chimex for just this situation. WMW sells it for $20, plug it in like a seatbelt, no chime.
However, when I place something in the passenger seat I use the passenger seatbelt to help keep the something in place.
That way my food take-out does not go flying when I take the first turn.
Back on topic. My R59 is currently at the body shop (sigh) so I can't test things. The recent app release, and dropping specific Gen2 models from the website documentation gives me new hope.
If you download the free version the app will show you which codes it found and what it can change. Previously with the R59 there was just not much it could do.
In about 2 weeks I will be able see if things have changed.
#58
All the ones I want (Side markers, Turns, Running Lights, Rear Fog, Brake Lights, interior lights..) They turn on "soft" for 20 seconds (time is also code able)
I tried the "use fog lights as cornering lights".. can't tell yet if they work or not.. sort of hard to get out in front of the car when its moving.
As a side note you have to have the headlights in the "on" position or "automatic" for this to work. If you turn them fully "off" they will not light up for the welcome.
#59
I am assuming you are putting something heavy on the passenger seat and your Mini starts beeping because it thinks a real person is sitting there.
#60
#61
On the R55/56/57, the passenger seat occupancy sensor can be coded out, because the dealer-fit JCW Recaro seats (not the short-lived factory option ones) don't have occupancy sensors.
However on the R58/59, this can't be coded, because those cars are not approved for fitting the JCW Recaros. Or at least that's what my dealer told me when I bought some JCW Recaros and tried to have them coded.
Incidentally, the extra height of the JCW Recaros in a R58/59 is a real problem, so I probably wasn't going to keep them anyway.
#62
I tried to code the fog lights as cornering lights, but they don't work.
#63
#64
on
I bought the iViNi OBDII WifI adaptor for BMW for use with the iPhone and iPad and BMWhat on Amazon last night and because I have Prime it will be here tomorrow afternoon. I downloaded the BMWhat lite App from Apple App store to test it with before buying the whole app. It says it is compatable with the iPad but haven't been able to download to my I pad. Being older it would be nice to be able to use it on the iPad instead of the iPhone 5. This coding stuff has me intrigued. We shall see tomorrow evening.
Tom
Tom
#65
#66
I used NCS and actually preferred using NCS and felt safer. I don't trust the BMWHAT app and I know exactly what changes I am making with NCS.
#67
I used app on a 2015 r59 today. App worked for fog light stay on with high beam on but the features of one touch windows from switch and also key fob windows is not available on the app. I did code both of these with NCS. I also coded out seatbelt chime with NCS on the 2015 r59. 53.0.5 Datens worked.
#68
on
I am having trouble or doing some thing wrong. 2011 Clubman. BMWhat full with the iVINi OBDII Wifi Adapter, using iPhone 5 and iPad. The app both the lite version and full version find the adapter other an and it cant the the ECU or check for Cods nothing compatible. Now when I firs connected every thing both with the full an lite the app found very thing like it was supposed to. What am I dong wrong? Will go out and try in later think I will shut off the blue tooth on phone and ipad maybe it is getting confused. The phone is paired to the car for using hands free phone so that may be a problem.
Tom
Tom
#69
I found it was necessary to have the phone powered up in the car (with a charge cable) so it did not go to sleep - the car also has to be running.
Delete the "lite" version off the devices, turn off Bluetooth.. that helped me some.. now it connects every time..
#70
on
Dan
Did as you suggested and it worked. Have to turn off Blue Tooth in car besides iphone or iPad. Have blue took key board on iPad. Got rid of lite and then reloaded the full version and restarted iPad. I start car before plugging in WiFI adapter and the started app and every thing seem to work have 3 ECU's that can be coded.not to learn what it all means. be for changing anything. Thanks for the help. This little car and it electronics is amazing. Now to get ahold of my Brother in Laws BMV he he he.
Tom
Tom
#71
I asked them for this (especially for the 25W retrofit and build date <2009) and the answer is:
unfortunately this coding is too specific for BMWhat at the moment.
As soon as we get more requests for this, we’ll start to work on it :-)
#72
The BMWhat bluetooth adapter came today but no coding is available for my 11/2007 R56. So i 've ordered the BMWhat USB-OBD cable with Micro-USB OTG adapter.
A lil bit disappointed but excited at the same time..
Scratch the above. I have set it to the automatic recognition and it stated that i have a R50. So i 've put R56, 2007 and voila everything works!
#74
I don't have fogs, I have the position lights. I put LED bulbs in and was able to code them to run as DRL'S
#75
I used this last weekend, I don't recommend turning on the setting "doors lock when key in ignition" (or something like that)
ANYtime the key is in the doors will lock. Including when you open the door, leave the car running, and shut the door. The locks immediately lock. And if you have a 2nd key and you hit unlock, they will lock half a second later, so you have to be quick opening the door.
This happened to me when stopping at the gas station to pick something up a soda. Luckily I live less than a mile away and my wife was still home. She came by and unlocked the car.
Needless to say, I changed that setting right away.
