Drivetrain eBay intercooler the same as FORGE?
#27
If you're worried about a few tiny little fins being bent, that's just being a bit OCD don't you think? Those bent fins won't affect performance one bit. It looks like it cost more than you paid considering it's most likely a product of China. My radiators from my water cooled computer are ultra expensive and even after spending serious money there were a few bent fins.
#28
want to know why there are no cases like that? because it hasnt happened nor will it ever happen...
if you're talking generic head gasket or a generic piston ring set, or a generic pulley kit, ya you'd have to be an idiot to buy those non name brand items but as far as intakes, intercoolers, intercooler piping, exhausts, and basically any other sort of pipes and static items(no moving parts), generic works as well, if not better than name brand parts
#29
agree 100% here with luigi90210. An intercooler wont fudge up your engine. These things know when something isnt right most of the time anyways. If your worried about an intercooler, you probably wouldnt be happy with the 3" peice of pvc i am using to cut out the noisemaker on the intake side. I agree most of the time you get what you pay for, but in this case the worst that can happen is bad performance. But its worth a try IMO
#31
yes, doing a boost leak test will help determine if the welds on the intercooler are good(most likely they are since they are welded using welding machines), worst case you need to reweld something which should cost less than $50 at an exhaust shop
#32
To pressure test:
Go to Home Depot plumbing department and get:
1. Rubber cap (size to match fmic horn)
2. Rubber coupling (size to match fmic horn)
3. Pvc cap for the coupling
4. Schrader valve
2. Hose clamps
Insert the pvc cap in the one end of rubber coupling and hose clamp tight. Drill a hole for the Schrader valve in the pvc cap. Apply assembly to one end of the fmic horn with another band clamp. Take the rubber cap and hose clamp to the other horn. Pressurize the fmic with the Schrader valve and check for leaks or leak down on a gauge.
#33
It's not the welding machine I'd be worried about, it's the guy holding the stick.... If there is a issue after a pressure test is done, I would bring it to someone that can TIG with aluminum stick really well. Most exhaust shops mainly MIG and or TIG stainless.
To pressure test:
4. Schrader valve
2. Hose clamps
To pressure test:
4. Schrader valve
2. Hose clamps
this is typically what an automated welding machine looks like
#34
Luigi- I will send you a pm about automated welding and it's place. Not going to sidetrack this thread.
Op- good luck with the fmic. You can always use the pressure testing parts to check for boost leaks in the future if there is ever a suspected issue. Just connect to the turbo and test the system that way.
#36
#37
Im not sure who the many many people you are reffering too. There have been tons and tons of people that own supras,v8's,rx7's,evo's and every other turbo car on the planet that has made crazy power and had amazing luck with ebay intercoolers. Years ago on the supra forums they did a comparsion test of a high dollar instercooler vs a ebay cheap intercooler with very very little difference in power and IAT's.
Alot of the cheap intercooler are made over seas which is where alot of the higher end companies sub out their parts from because its made cheaper. When your talking about 250-300hp you dont need a million dollar intercooler. Especially when your comparing it too the stock intercooler.
#40
#43
#44
#49
Turbo lag, a larger intercooling doesn't have anything to do with turbo lag. Turbo lag has to do with the nature of the turbo itself, turbos build boost exponentially (over time) where a supercharge gives you rated boost instantly. Using a larger intercooler with decrease your boost by .5 psi, but lowering your intake temps will balance things out. Cooler intake temps will improve performance vs losing .5 psi, I'll take the .5 psi drop in exchange for cooler intake temps any day!
If you plan on getting at least a Stage 1 Tune from Battle or Manic the intercooler is much more important because you'll have way more boost anyway, you don't want detonation when running higher boost than stock or your engine will eat itself! Tuners actually recommend an intercooler when thinking about getting a tune, you'll be producing more heat and heat leads to more stress on your engine. That's why I also plan on getting W/M injection to really cooling intake temperatures.
#50
Turbo lag, a larger intercooling doesn't have anything to do with turbo lag. Turbo lag has to do with the nature of the turbo itself, turbos build boost exponentially (over time) where a supercharge gives you rated boost instantly. Using a larger intercooler with decrease your boost by .5 psi, but lowering your intake temps will balance things out. Cooler intake temps will improve performance vs losing .5 psi, I'll take the .5 psi drop in exchange for cooler intake temps any day! If you plan on getting at least a Stage 1 Tune from Battle or Manic the intercooler is much more important because you'll have way more boost than anyway, you don't want detonation when running higher boost than stock or your engine will eat itself!
