F56/F55 Wheels
Old 11-12-2017, 08:54 PM
cmdycrzr's Avatar
cmdycrzr
cmdycrzr is offline
F56/F55 Wheels
Let's see what you've got on your Gen3...OEM or custom!
Contemplating these for springtime...https://www.discounttiredirect.com/b...g-dr-9/p/13858
Old 11-12-2017, 09:12 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
NM RSe05 17X7.5
16 pound wheel
Attached Thumbnails F56/F55 Wheels-fullsizeoutput_15f.jpeg
The following 3 users liked this post by vetsvette:
cmdycrzr (11-12-2017), ECSTuning (12-27-2017), jchaperon (04-28-2018)
Old 11-16-2017, 05:30 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
OEM "Roulette Wheels". Got them from Allmag Auto in Florida. My car came with the JCW exterior package and the wheels are nice and all... But something about the roulette wheels just calls out to me. They're heavy but so pretty!
F56/F55 Wheels-photo112.jpg
cmdycrzr (11-16-2017)
Old 11-16-2017, 06:22 PM
SFMCS's Avatar
SFMCS
SFMCS is offline
Montegi by American Racing via/Discount Tire
Old 12-23-2017, 07:49 AM
ridgemanron's Avatar
ridgemanron
ridgemanron is offline
Originally Posted by vetsvette
NM RSe05 17X7.5
16 pound wheel
Saw these wheels in Matte Black at new.minimania and wanted
to know if I can re-use the JCW caps that came with my 'standard'
OEM JCW wheels on my 2018 JCW Convertible?
Old 12-24-2017, 03:26 AM
KF55's Avatar
KF55
KF55 is offline
I went with these same wheels on my F56 JCW - they mount right up with no hub rings and the OEM center caps transfer over easily. The black is a nice complement to the wheels arches as well.
Old 12-24-2017, 06:22 AM
ridgemanron
Thanks for the info.
Was able to come across the Neuspeed install instructions:
http://www.neuspeed.com/media/attach..._UserGuide.pdf
They mention having to get dealership to reset the TPMS
software, also stating that wheel install needs to avoid using
impact wrench or air gun with the Lug Torque to be 125 N-m
(90 Lbs-Ft) and the lug bolt tightening order spec to be
1 - @ 12 O'Clock
2 - @ 5 O'Clock
3 - @ 9 O'Clock
4 - @ 3 O'Clock
5 - @ 7 O.Clock
The Neuspeed RSE05's come in two 17" wheel variants. The custom
fit variant for our JCW cars is Spec 17 X 7.5, Offset +40, Center
Bore 66.5 mm, whereas for VW and Audi they measure 17 X 8,
Offset +45, and Center Bore 57.1. We would need to use spacers
with this variant. The pricing I found that was the lowest for 4 wheels
in the JCW variation is at ECS Tuning. $957.42 plus Shipping of $125.
Mini Mania was the other listing for the JCW version but they totaled
$1,119.80 plus $200 Shipping. Guess which ones I decided on ordering?
The following 2 users liked this post by ridgemanron:
Old 01-06-2018, 10:44 AM
JimVL's Avatar
JimVL
JimVL is offline
Today I replaced the original Hankook Optimo's tires with Bridgestone Driveguards, 195/55RF15 87V.
Old 01-08-2018, 03:07 AM
Clutch Wotan's Avatar
Clutch Wotan
Clutch Wotan is offline
NM RSe05 17X7.5
16 pound wheel
that 7,2 Kilos that not bad
- What is the offset ?
- are they forged ?,
- how many kgs are they in 16x7,5 ?
That are my track shoes for 2018
Forged 16x7,5 finish natural
Facebook Post
Old 01-08-2018, 06:14 AM
vetsvette's Avatar
vetsvette
Moderator
Correction: 17 pound wheel
ET40
They are only available in 17 and 18"
Old 04-10-2018, 09:38 AM
Minijons's Avatar
Minijons
Minijons is offline
Finally got new wheels/tires
After months of thinking about it and waiting for winter to be over (still waiting...), I finally got these installed yesterday.
17" OZ Supertourismo LM
205/45/17 Bridgestone g-force Comp 2 A/S (I got too impatient for summer tires, still cold in CLE)
The installer noted that they were rubbing the front struts. After calling Tirerack, they said they were a guarantee fit so had the installer contact them. They advised putting the rims on, and lowering the car to the ground to get weight on the suspension. There's now a 2mm gap between tire and front strut. So gonna drive a bit on them and head back to the shop to make sure everything's still good.
Cheers!
Attached Thumbnails F56/F55 Wheels-sideprofile.jpg   F56/F55 Wheels-frontquarter.jpg
Old 04-10-2018, 10:31 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
(90 Lbs-Ft)
1 - @ 12 O'Clock
2 - @ 5 O'Clock
3 - @ 9 O'Clock
4 - @ 3 O'Clock
5 - @ 7 O.Clock
Just noticed this post and the instructions for torque on these wheels. That 90 ft lbs is not for a 3rd generation MINI. I used 101 as per the owners manual. I'm pretty sure you use manufacturers specs and not wheel mfg numbers which were more likely from prior gens.
If you followed this you might want to break out the wrench and tighten it up a bit.
Old 04-11-2018, 12:09 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
Old 04-12-2018, 08:50 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
^ has a big wing to kit it floating And its a red bull car so it has wings.
Old 08-09-2018, 10:12 AM
Knovako2's Avatar
Knovako2
Knovako2 is offline
Vetsvette, these are awesome wheels. They are light and look fantastic. Also one of my the very few that will clear JCW calipers. With 215-45/17 handles like in rails
ECSTuning (08-09-2018)
Old 08-09-2018, 10:14 AM
Knovako2's Avatar
Knovako2
Knovako2 is offline
Rse05
The following 3 users liked this post by Knovako2:
bratling (08-10-2018), ECSTuning (08-09-2018), vetsvette (01-18-2019)
Old 08-10-2018, 12:44 AM
Andrew Park's Avatar
Andrew Park
Andrew Park is offline
Sparco Pro Corsa 17x7.5 +48
Continental Extreme Contact DSW 06 215/45/ZR17
The following 7 users liked this post by Andrew Park:
6FT6 (08-12-2018), Afrothunder_72 (08-11-2018), bratling (08-10-2018), Cspinm (06-19-2019), easter (08-11-2018), ice180 (07-27-2021), shmandrew (08-11-2018) and 2 others liked this post. (Show less...)
Old 08-11-2018, 02:06 PM
shmandrew's Avatar
shmandrew
shmandrew is offline
3SDM 0.66 18x8.5 ET42. Custom full matte black finish.
Michelin Pilot Sport 4S 225/40/18
The following 3 users liked this post by shmandrew:
Afrothunder_72 (08-11-2018), ECSTuning (08-15-2018), J_L (08-16-2018)
Old 08-17-2018, 07:45 PM
JuanJo73's Avatar
JuanJo73
JuanJo73 is offline
Did somebody know what brand are this rims
Old 01-18-2019, 06:11 PM
cmdycrzr's Avatar
cmdycrzr
cmdycrzr is offline
Wound up getting these Touren TR72 wheels, 17". Photo taken on Daytona Beach
Old 02-16-2019, 08:01 PM
saru9999's Avatar
saru9999
saru9999 is offline
Verde Saga on Toyo 205 45 17
Old 02-24-2019, 07:01 PM
GTODave's Avatar
GTODave
GTODave is offline
Cheers!
howd it all work out? My wife has a 4 door S and I’m thinking of getting the Konig Oversteer rims in 17x8 but the site I looked at said they wouldn’t fit. She has factory 16’s. Bolt pattern and offset are the same as other rims that say are ok. Maybe the 8” width is the problem? Wondering what the problem would be. I see others on this thread have 8” wide rims. Any advice? Btw everything on it is stock.
Dave
Old 02-24-2019, 07:16 PM
co0p3r's Avatar
co0p3r
co0p3r is offline
Old 02-25-2019, 04:50 AM
Minijons's Avatar
Minijons
Minijons is offline
It all worked out great, love the look and no rubbing issues at all. I think the 8 in wide rims are the issue. I'm not an expert in this subject at all, but you may need to add some spacers to give more room for your struts/suspension parts, but it also depends on how wide the tire is. I'd do a bunch of searching on here to see what others have done in terms of spacers and tire size in order to get 17 x 8 rims to fit.
My experience using tire rack was pretty seemless really, I'd use them again for anything rim/tire in the future. Had the wheels shipped to the local approved shop and only had to pay $40 to install them.
The following 2 users liked this post by Minijons:
GTODave (02-25-2019), tfranciscojavier (06-19-2019)
Old 06-07-2019, 11:03 AM
tfranciscojavier's Avatar
tfranciscojavier
tfranciscojavier is offline
Talking wheels fitment
Can I replace my wheels for a set of OZ 19x8 ET35???
