ECS Caliper Guide Bushings New* | Hotchkis Now @ ECS
ECSTuning MINI R50/R52/R53 ECS Caliper Guide Bushing Upgrade Kit Your factory brake calipers slide on guide pins through rubber bushings. This design is adequate and widely used from the factory by MINI. For more precise braking, bronze bushings and 304 stainless steel guide pins allow for a more positive feel at the pedal and more even pad wear. The ECS Performance Caliper Guide Bushings are oil-impregnated to complement anti-seize, providing additional lubrication - all of which is held in place by an integrated o-ring & dust cap. http://0c6ae9a232ed4697ae13-6a9cf06e...6_21759_01.jpg Fits: R50 MINI Cooper (2002-2006) R52 MINI Cooper / S (2005-2008) R53 MINI Cooper S (2002-2006) *Non JCW Front Brakes Click HERE ------------------------------------------------------------------------ ------------------------------------------------------------------------ Hotchkis Gen 1 MINIs Reduce suspension movement for increased traction and stability! With these cambers links and front and rear sway bars you can set your MINI up for the track or daily driving. With these arms (links) you may easily adjust rear toe, which keeps tire wear at bay and to replace the factory bushings with durable grease fitted bushings mounts that offer more duration. If you've lowered your vehicle more than stock, these may be required to bring the rear toe angles into specification. These arms may be used in conjunction with rear camber arms for full adjustablility in the rear on lowered vehicles. These sway bars and camber links are serviceable with the integrated grease fitting on each bushing allowing you to add grease when needed. One of the first in the MINI performance game now carried at ECS! http://0c6ae9a232ed4697ae13-6a9cf06e...6_21788_01.jpg Gen1 Fits: R50 MINI Cooper (2002-7/2006) R53 MINI Cooper S / JCW (2002-7/2006) R52 MINI Cooper Convertible /S/JCW (2005-7/2006) Click HERE ------------ Hotchkis Gen 2 MINIs Reduce suspension movement for increased traction and stability! With these arms (links) you may easily adjust rear toe, which keeps tire wear at bay and to replace the factory bushings with durable grease fitted bushings mounts that offer more duration. If you've lowered your vehicle more than stock, these may be required to bring the rear toe angles into specification. These arms may be used in conjunction with rear camber arms for full adjustablility in the rear on lowered vehicles. These are serviceable with integrated grease fitting on each bushing for easy maintenance. http://0c6ae9a232ed4697ae13-6a9cf06e...6_21783_01.jpg Adjust the rear camber more than stock. Gen2 R56 MINI Cooper / S / JCW (2007+) R55 MINI Cooper Clubman / S / JCW (2008+) R57 MINI Cooper Convertible / S / JCW (2009+) R58 MINI Coupe' / S / JCW (2012+) R59 MINI Roadster / S / JCW (2012+) R60 MINI Countryman / S / SX / JCW (2011+) R61 MINI Paceman / S / SX / JCW (2013+) Click HERE |
