:: ECS Tuning :: ECS CF Intakes *Free Ship* = Oil Turbo Line Kits = EURO Taillights
Old Jun 16, 2015 | 11:44 AM
MINI R60/R61 Coolant Expansion Tanks
ECS is now offering a full kit expansion tank replacements for the MINI R60/R61.
Available are ECS-assembled and Genuine MINI replacement options.
The Forge polished alloy tank is a direct-fit replacement for the factory unit, and completely resists the cracking and fading of the original part.
The alloy coolant tank also adds a high-performance, premium look to your engine bay.
Each kit includes a new coolant expansion tank, tank cap, grommet, and torx bolt.
Expand Your Limits
Fits:
R60 MINI Countryman /S/ SX(ALL4)/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE For expansion tank kits
MINI Gen2 Turbo Oil Line Kit
Turbochargers operate at speeds at over over 100,000 rpms. The lubrication requirements for this type of system are understandably highly specific and critical to observe carefully.
The MINI S/JCW feed & return oil lines have a tendency to weaken due primarily to heat exposure, making oil delivery precarious, compromising overall engine health
The Genuine MINI Turbo Oil Line Kit includes both new return and feed oil lines, as well as a heat resistant plate that installs on the new oil pipe for protection from further damage.
Each kit also includes all installation hardware.
Lubricious
Fits:
R56 MINI Cooper S/JCW (2007-2013)
Click HERE for turbo oil kits
MINI R55-R57 S/JCW ECS Kohlefaser Luft-Technik Intake
"Good things come to those who wait." This proverb is arguably the best definition for our ECS Tuning Kohlefaser Luft-Technik (Carbon Fiber Air Technology) Intake System.
In house developed, engineered and tested, this air induction system is THE BEST production induction system on the market today.
With months of rigorous testing and design innovations we are proud to release this complete kit to power your MINI Cooper S/JCW '07+.
With more power, higher quality materials and stunning aesthetics, this induction system will exceed expectations.
Fits:
Fits MINI:
R55 MINI Clubman S/JCW (2008-2014)
R57 MINI Cooper Convertible S/JCW (2009+)
Click HERE For ECS CF intake
MINI R58/R59 Kohlefaser Luft-Technik Intake System
With months of rigorous testing and design innovations we are proud to release this complete kit to power your MINI.
The Apex of Induction Engineering
Fits:
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Click HERE For the ECS Intake System
R60/R61 Kohlefaser Luft-Technik Intake System
Fits:
R52 Convertible Top Rear Trunk Molding
Exposure to sunlight, dirt, and harmful chemicals ages your MINI R52 Convertible trim, moldings, and seals between the convertible top and body. Eventually they will certainly fade, crack, and leak.
Don't wait for water and dirt to permanently damage your trunk interior and its valuable contents.
The original MINI convertible top molding kit comes with everything you need to do a professional-grade fix using common hand tools.
Zero cutting, fitting, or trimming required; this complete repair solution includes all the screws and hardware you'll need for a painless installation.
Seal the Deal
Fits:
R52 MINI Cooper Convertible (2005-2008)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE For trim kits
R50 R52 R53 Euro Tail Lights
Be bold. Bodacious! Bolt on beautiful European tail light kits for a look that makes your MINI turn heads.
The kit includes a complete set of three light assemblies: left and right rear tail lights in red/ white with top center brake light in clear that lights up led red. Go Euro with the early style three bulb light integration, with turn signal in center.
No special wiring. No coding or special switches needed. Plug. Play.
Light'em Up!
Fits:
R50 MINI Cooper (7/2004-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
R53 MINI Cooper S / JCW (7/2004-2006)
Click HERE For Euro Taillights
MINI R61 ECS Wheel Spacers
ECS Tuning lets you tweak your ride for the perfect wheel fitment and stance with MINI R61 ECS Wheel Spacers.
Choose from our huge inventory of hub centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget.
All spacers are corrosion protected, aircraft-grade 6061-T6 aluminum; sizes range from 5 to 20mm.
Buy them as a pair with or without matching lug bolts.
Space Out
Fits:
R61 MINI Paceman / S/ SX(ALL4)/ JCW (2013+)
Click HERE For ECS Wheel Spacers
R56 R55 R57 MINI Schroth Quick Fit Harness
A frequent dilemma when fitting an upgraded seat belt to track-prepared street cars is how to balance the needs of daily driving with the demands of performance driving.
A dedicated track-day setup is typically impractical, while running without a substantial harness forces the driver to use the steering wheel to hold themselves in place.
Schroth Racing Quick Fit Harnesses are fully reversible and anchor to the factory seat belt pre-tensioner, allowing the airbags to deploy as the MINI engineers intended.
Both left (driver) and right (passenger) harnesses are available.
Track Ready!
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2014)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE For Schroth
MINI R60 Lowering Spring & Camber Kits
The MINI R60 is as capable transporting passengers as it is setting hot times at the track. Some simple performance upgrades, however, can bias this car more towards a pure-bred racer - and ECS supplies the best of them.
In order to maintain a consistent, performance-enhancing tire contact patch, the ability to control the camber angle is critical.
SPC Adjustable Rear Control Arms allow for a full +/- 4.0 degrees of rear camber change.
NM RSα and H&R progressive rate spring kits provide a responsive ride, sharper handling characteristics and lowered ride height for the R60.
Tweaked Out
Fits:
R60 MINI Countryman SX(ALL4)/ JCW (2011+)
Click HERE For suspension options
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
M7Speed
Aug 6, 2015 01:48 PM
Aug 5, 2015 02:11 PM
