:: ECS Tuning :: New* Bentley Manual & SCHROTH Seat Belts & ECS Strut Tower Plates !
Old Oct 21, 2014 | 08:33 AM
R52 MINI Cooper Convertible Trunk Molding Kits
This kit is for the convertible MINI to seal the top fabric to the boot / trunk upper panels. The seal can start to deteriorate over time and peel along with the chrome trim fading.
The kits seal the bottom of the convertible top to the truck cabin and keep the dirt and water out.
So if yours is looking old, replace it and restore the look of your MINI convertible.
This kit is for the left and right hand side in the rear of the vehicle.
It's the little things.
Fits:
R52 MINI Cooper Convertible (2005-2008)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for convertible top rear trim kits
R56 R55 R57 MINI Pipercross JCW Performance Air Filter
All engine performance starts with air. Gobs of air, filtered to protect internal engine surfaces from abrasion. That's why European motorsport racing teams have relied on Pipercross Performance Air Filters for a quarter century.
Their unique filter media reduces the pressure drop at the filter while maintaining high filtration efficiency--the ultimate goal of any filter design. Now you can add the benefits of this premium filter to your car with our new and growing line of Pipercross filters.
Washable and reusable, a Pipercross may be the last filter you buy for your car.
Air You Go!
Fits MINI:
R56 MINI Cooper S (2007-8/2010)* & JCW (2009-2012)*
R55 MINI Clubman S (2008-8/2010)* & JCW (2009-2012)*
R57 MINI Cooper Convertible S (2009-8/2010)* & JCW (2009-2012)*
*JCW Tuning Kit Airbox
Click HERE for the Pipercross tube filter
R55 R56 R57 MINI Bentley Service Manual NEW* And updated
Guesswork is expensive. It leads to costly repair errors that compromise vehicle safety. Talented pro-sumer or repair professional, you need accurate vehicle data and specifications.
That's why ECS is happy to provide you with the Robert Bentley repair manuals; A reliable, respected source of repair data for many European vehicles.
Pages are carefully edited and illustrated. A worthwhile investment.
At Your Service
Fits :
R55 MINI Clubman /S/JCW (2008-2013)
R56 MINI Cooper /S/JCW (2007-2013)
R57 MINI Cooper Convertible /S/JCW (2009-2013)
Click HERE For the Newest Bentley Manual.
MINI R52 Convertible Schroth Quick Fit Harness
A frequent dilemma when fitting an upgraded seat belt to track-prepared street cars is how to balance the needs of daily driving with the demands of performance driving.
A dedicated track-day setup is typically impractical, while running without a substantial harness forces the driver to use the steering wheel to hold themselves in place.
Schroth Racing Quick Fit Harnesses are fully reversible and anchor to the factory seat belt pre-tensioner, allowing the airbags to deploy as the MINI engineers intended.
Both left (driver) and right (passenger) harnesses are available.
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for Schroth .
R50 MINI South Bend Clutch Kits
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. This dedication to product specialization makes today's South Bend products incredibly refined.
Three stages & three driving styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
The torque requirements of daily drivers, track or drift cars, high-powered street cars, & dedicated race cars are covered by 195ft/lbs. through 320ft/lbs. clutch ratings.
So Clutch
Fits:
R50 MINI Cooper (2002-7/2004)
Click HERE for clutch kits from South Bend .
MINI R50/R52 (NON S) GEN1 South Bend Clutch Kit
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. This dedication to product specialization makes today's South Bend products better refined compared to larger distributors.
Two Stages & Two driving styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
From daily driven to track cars they have you covered.
So Clutch
Fits:
R50 MINI Cooper (7/2004-2006)
Click HERE for the clutch kits
R56 MINI Cooper/S H&R Cup Kit
The H&R Cup Kit is now available for your R56 MINI Cooper/S, allowing for an average of 2 inches of ride height adjustability for a lower center of gravity and improved handling.
Cup Kits are a superb solution for those MINI owners seeking to add a increased performance dimension while retaining daily drivability and ease of installation.
Manufactured from high-grade steel, and featuring adjustable damping, this suspension arrangement is an ideal lowering and performance-enhancing solution.
Strong German Heritage
Fits:
R56 MINI Cooper/S (2007+)
Click HERE for the H&R Cup kit
R55 R56 R57 MINI Windshield Cowl Kit
By now, sun and the elements have undoubtedly taken their toll on your MINI's cowl covers. Once a dark matte black finish, they have probably faded to gray, requiring constant attention to keep them looking good.
Both sides of this cowl cover are more than a styling statement; one has a built-in access panel to the brake fluid reservoir, and the other has an integrated battery cover.
Form and Function
Fits:
R56 MINI Cooper / S / JCW (2007+)
R55 MINI Clubman / S / JCW (2008+)
R57 MINI Convertible / S / JCW (2009+)
Click HERE for the cowl kits
MINI R55-R59 ECS Strut Tower Plates
The strut tower for the MINI Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Aging models or vehicles that are routinely pushed past the limitations of the chassis oftentimes experience strut tower deformation, compromising the crisp and responsive handling that defines every MINI.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity.
ECS Smart and Simple
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for the ECS STP kits
R50 R53 MINI Schroth Quick Fit Harness
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE for Schroth seat belts
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
