:: ECS Tuning :: H&R Sway Bars ( Free Ship ) // R56 Ziza Reverse LEDS // ECS Brakes
MINI R56 Cooper S JCW H&R Sway Bars ;; Free Ship
The MINI S and JCW comes with an excellent handling package, but there's always room for improvement. Let H&R up your game with suspension products that pick up where MINI left off.
Made in Germany, H&R sport springs, sway bars, and adjustable coilovers are built on decades of experience designing world class suspension upgrades; then manufactured to old world standards where "excellence" is more than just a word.
Don't compromise. Demand H&R.
Fits:
R56 MINI Cooper S (2007+)
R56 MINI Cooper JCW (2007+)
[B]Click HERE for the H&R Sway bars & kits
MINI R56 Cooper Base H&R Rear Sway Bars
The MINI Cooper comes with an excellent handling package, but there's always room for improvement. Let H&R up your game with suspension products that pick up where MINI left off.
Fits:
R56 MINI Cooper Base (2007+)
Click HERE for MINI "Justa" Cooper R56 information.
R58 & R59 MINI Cooper Mann Cabin Filter
Clogged or dirty cabin air filters can significantly reduce airflow from the cabin vents, as well as introduce allergens into the cabin air stream.
By filtering out dust and dirt, those contaminants don't make it into your HVAC system, making everything work easier and cleaner. This part slides up with one end and curves down with the other. Snap the plastic door shut on all sides and you’re ready for clean cabin air.
Breathe Easy.
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for Cabin filters or for more information.
MINI R61 Paceman S/SX ECS GEOMET® Brake Rotors
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits and reduce fade, select a drilled and slotted ECS GEOMET® rotor.
Cross-drilling dissipates heat faster for better braking and reduced fade.
Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface to further enhance braking performance.
Featuring GEOMET® protective coating.
Fits:
R61 MINI Paceman S (2013+)
R61 MINI Paceman SX (ALL4) (2013+)
Click HERE for ECS Geomet Rotors or for more information.
MINI R56/R57 LED Reverse Light Kit
Tired of that sickly flicker from your reverse lights? Want some real light back there? Useful light? Light that lets people know you are backing? Light that better illuminates behind you for added safety?
If so, what you need is a set of Ziza LED reverse lights. Brighter than stock, these direct fit LEDs cast a bright white light, far more useful than the puny yellow glow from stock bulbs.
The bulbs have a standard bayonet base that fits stock sockets perfectly; with metal heat sinks to keep them cool. Twist out the old bulbs; twist in the new.
Fits:
R56 MINI Cooper /S/JCW (2007-8/2010)
R57 MINI Convertible /S/JCW (2009-8/2010)
Click HERE for MINI Ziza Reverse Lights or for more information.
MINI Paceman ECS Exact-Fit Stainless Brake Lines
ECS Exact-Fit stainless reinforced brake lines provide more confident and dependable stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Fits MINI:
R61 MINI Paceman (2013+)
R61 MINI Paceman SX (ALL4)(2013+)
R61 MINI Paceman JCW (2013+)
Click HERE for Paceman ECS Exact-Fit Stainless Brake Lines or for more information.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
