:: ECS Tuning :: JCW Badge $ // Aux Input Kit // Mann Filters // Countryman Mickey
Old Apr 4, 2014 | 12:12 PM
Badges for a less.
Add either one (or both) of these trunk lid/front grille badges to your MINI driver, for a Gen2 JCW look. Or use in multiple locations for a touch of JCW on the exterior or interior.
The bold black/red on chrome surfboard design adds a distinctive accent to any MINI.
Peel-and-stick-easy to install, this is an essential upgrade for the discriminating MINI owner.
The Works
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Coupe /S/JCW (2011+)
R59 MINI Roadster /S/JCW (2012+)
R60 MINI Countryman /S/SX/JCW (2011+)*
R61 MINI Paceman /S/SX/JCW (2013+)*
*Rear JCW Badge Only
Click HERE for JCW Badges .
Power Steering Line Repair Kit for R50/R52/R53 MINI
The MINI power steering line repair kit was made to repair both the return and suction line that are located between the power steering pump and reservoir.
These lines are known to leak, requiring replacement. Genuine MINI parts guarantee fitment and longevity, so you take care of this job the right way the first time.
The kit is complete - The power steering return line, suction line, suction line clamps (upper and lower), return line upper clamp, two return line washers, sealing ring, and hollow bolt are all included.
Steer Clear
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper / S / JCW ( 2005-2008 )
R53 MINI Cooper S / JCW ( 2002-2006 )
Click HERE for Power Steering Lines repair kit or for more information.
MINI Gen 1 Aux Input Cable Retrofit Kit
When you're on a long driving adventure, you can't trust FM radio or your scratched CD collection to provide for your listening needs. Take advantage of modern music players with this 3.5mm jack Aux Cable retrofit kit.
This Genuine MINI kit includes a comprehensive factory installation guide and all necessary hardware. You can even mount it in the factory glovebox location. Expand your auditory options while preserving the factory stereo system!
* Only compatible with MINI factory stereo decks in first generation MINIs. Does not work with 2002 models or cassette deck stereos.
Fits:
• R50 MINI Cooper (2003-2006)
• R52 MINI Cooper Convertible S / JCW (2005-2008)
• R53 MINI Cooper S / JCW(2003-2006)
*Does not fit 2002 MINIs.
Click HERE for MINI Aux Input kit or for more information.
MINI Cooper Gen 2 Armrest Lid
An especially conspicuous wearing part in the cabin of your R55/R56 MINI is the armrest lid. Spirited shifting is often the main culprit, while years of regular use and neglect don't help.
Genuine Armrest Lid replacements mean exact color matching and factory-quality direct fitment.
Put a lid on it
Fits:
Also fits:
Click HERE for Genuine MINI Replacement armrest lid or for more information.
MINI R50/52/53 Mann Cabin Filter
Clogged or dirty cabin air filters can significantly reduce airflow from the cabin vents, as well as introduce allergens into the cabin air stream. By filtering out dust and dirt, those contaminants don't make it into your HVAC system, making everything work easier and cleaner. This is an active carbon filter, which helps prevent incoming odors from permeating the cabin.
When replacing your cabin air filter, also consider changing out your air, fuel and oil filters as well. Typically, these four are done during your regularly scheduled maintenance.
Carbon Free Cabin.
Fits:
•R50 MINI Cooper (2002-2006)
•R53 MINI Cooper S/JCW (2002-2006)
•R52 MINI Cooper Convertible/S/JCW (2005-2008)
Click HERE for MINI Mann Cabin Filter or for more information.
MINI Countryman Piano Black with Chrome Trim Set
This kit is a genuine MINI trim upgrade from the gray to the newer piano black with chrome, which matches the dash. These easily snap into location in place of the original trim. A complete set for an instant upgrade to the interior.
Incudes:
Center Mickey - Piano Black with chrome.
Left and right outside dash vents in piano black/chrome.
Fits MINI:
R60 MINI Countryman (2011+)
R60 MINI Countryman S (2011+)
R60 MINI Countryman SX (ALL4) (2011+)
R60 MINI Countryman JCW(2013+)
Click HERE for MINI Countryman Dash Trim kit or for more information.
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
