:: ECS Tuning :: Pipercross Filters // MINI Convertible Trim Kits // OEM Stripes
Your 1st Generation MINI (Non S) is a masterpiece of engineering that pumps out power with incredible fuel efficiency. Sophisticated as it is, however, it still needs thousands of gallons of air to burn a single gallon of fuel.
Don't settle for stock. Pick Pipercross filters, designed with a progressive foam filter media that promotes air flows, without compromising filtration efficiency.
Track tested for the last quarter century, Pipercross Performance Filters are durable, cleanable, and tough enough to protect your engine for years and thousands of miles.
Square Filter Fits:
R50 MINI Cooper up to 7/2004 - all transmission types
R50 MINI Cooper /R52 MINI Cooper Convertible (Base) from 7/2004 - automatics only
Triangle Filter Fits:
R50 MINI Cooper /R52 MINI Cooper Convertible (Base) from 7/2004 - manuals only
Click HERE for Pipercorss ( NON S ) filters .
Pipercross
Your 1st Generation MINI Cooper S is a masterpiece of engineering that pumps out power with incredible fuel efficiency. Sophisticated as it is, however, it still needs thousands of gallons of air to burn a single gallon of fuel.
R53 MINI Cooper S (2002-2006)*
R52 MINI Cooper S Convertible (2005-2008)*
*non JCW Kit or Airbox
Click HERE for Pipercross or for more information.
MINI R52 Convertible Molding and Hardware Kit
This kit is for the convertible MINI to seal the top fabric to the boot / trunk upper panels. The seal can start to deteriorate over time and peel along with the chrome trim fading. They seal the bottom of the convertible top to the truck cabin and keep the dirt and water out. So if yours is looking old, replace it and restore the look of your MINI convertible.
This kit is for the left and right hand side in the rear of the vehicle.
Its the little things.
Fits:
R52 MINI Cooper Convertible (2005-2008)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for MINI Convertible trim kit or for more information.
MINI R57 Convertible Trim Kit
It's the little things.
Fits:
Gen 2
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE for Gen 2 Convertible trim or for more information.
R52 R53 Cooper S Solid Hood Stripe Set
From 1960's Rallye Monte Carlo to Dakar 2014, "Cooper" has sustained a well-earned association with motorsports brilliance.
Let this thoroughbred pedigree show on your sleeve with genuine OEM Hood Stripes.
Choose black or white - both come with protective coated installation paper for a perfect factory-finish look.
50+ Years of Racing Excellence
Fits:
R52 MINI Cooper S/JCW (2005-2008)
R53 MINI Cooper S/JCW (2002-2006)
Click HERE for Hood stripes sets or for more information.
MINI R56 R55 R57 Jack Pad Adapter
Take the danger and aggravation out of lifting your MINI with the ECS Tuning Jack Pad Adapter. Designed to fit the head of a standard floor jack, the adapter has a rectangular head that firmly engages the chassis jack pads.
Positive engagement at jack head and chassis resists jack slippage and shifting, while the raised adapter head prevents damage to rocker panel trim and underbody panels.
Made of black anodized aluminum for added strength and corrosion resistance, the adapter fits the head of most hydraulic floor jacks, including the Schwaben Low Boy.
Fits:
R56 MINI Cooper /S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
Click HERE for the Jack Pad Adapter or for more information.
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
