R53/2 Water Pumps In Stock Now! by Pelican Parts
Old May 15, 2013 | 11:35 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
In the case of the MINI Cooper S, the water pump is driven off the end of the supercharger. This setup is a bit different than most cars where the water pump is driven off the engine belts. When a water pump begins to fail, you’ll notice that the car tends to overheat at low engine speed, such as sitting at a stoplight. When you accelerate, the engine temperature will drop. Now, this is not always indicative of a water pump, but a good starting point.
We offer genuine MINI water pumps - you can shop HERE
We also offer a Water Pump Super Kit for both manual & auto transmissions:
-Water Pump and Gasket
-Thermostat
-Thermostat Housing Gasket
-12 oz. Redline Water Wetter Corrosion Treatment
-1 gallon of OEM MINI Coolant (must be mixed with distilled water)
-Expansion Tank or Thermostat Housing Cap
-Upper and Lower Radiator Hoses
Kits are listed HERE
Mark/Pelican Parts
888.280.7799 | 6am - 5pm PST
Cereall
Sep 5, 2019 06:05 PM
bobbiemartin
Jan 20, 2016 05:28 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
kpl
Aug 11, 2015 04:52 AM
kwijmbo
Aug 5, 2015 09:00 PM
