Prepare for Fall and Winter with ALTA
Our Fall Sale has been extended through this weekend, so if you missed it you have one more chance. Click HERE to check out the Fall Sale Post. Use Coupon code "fall08" upon checking out at the ALTA Performance web site to get 10% off all items.
Fall is here and Winter is coming!
Very soon most of us will be driving to work and driving home in the DARK. Along with the longer nights comes rain, fog & snow, all of which impairs your vision to some degree making it more and more dangerous to drive.
Now is the time to make sure your car is ready for the dark, rainy and snowy conditions of the Fall and Winter seasons. Don’t wait till its to late and you’re driving down a dark road with no clue as to what lies ahead because a head light is burnt out or your wiper blades are so old and worn that you might as well leave them off because they streak so bad.
Alta Performance has teamed with PIAA Corporation to give your car the premium visibility helpers your car needs. Yes it’s more fun to bolt on a new performance exhaust or a hot set of wheels but when you need to see, you NEED to SEE.
Wiper Blades
Set of PIAA Super Graphite (left and right side set)
All Mini ONLY $23.99
-Easy Installation
-Super Graphite Technology: A PIAA proprietary Molybdenum-Graphite binding process that works for you, longer.
-Smooth and quiet-no chatter
-Clearer visibility – No Streaking
Set of PIAA Super Silicone (left and right side set)
All Mini ONLY $35.99
-Easy Installation
-Activated silicone-coating action
-Revolutionary beading action
-Highest quality silicone rubber compound
-Resistant to all adverse climates-heat, ozone, and ultra-violet-for extended life
Bulbs
Replace those blown or dim bulbs with some high performance units from ALTA and PIAA. Believe it or not but bulbs do wear out over time. They are not at 100% then blow out, your headlights are NOT as good as when they where new as the bulbs get dimmer over time.
R53/50/52 Non-Xenon
>Low Beam = H7 type bulb
>High Beam = H7 type bulb
>Fog = H11 type bulb
R53/50/52 With Xenon
>Fog = H11 type bulb
R56 2007 Non-Xenon
>Fog = H11 type bulb
R56 2007 With Xenon
>Fog = H11 type bulb
R56/55 08-09 Non-Xenon
>High/Low Beam = H13 type bulb
>Fog = H11 type bulb
R56/55 08-09 With Xenon
>Fog = H11 type bulb
Lamin-X Lens Protection
In most areas, when they sand the roads in winter for traction it is actually small rocks, NOT sand. The cars ahead of you then fling all these little rocks all over your car resulting in chipped paint, cracked windshields and broken lights.
We at ALTA hate this but must adapt and live with it. That is why we have added the Lamin-X line of lens protection film.
Click HERE to check out the Lamin-X lens protection on the ALTA web site. When looking you will notice that most of the selections are also available in colors to add a bit of style. You can make your fog and headlamps yellow for that European look.
Go Mini Go Brake Pulsar
Believe it or not but your Mini is a small car that might be hard to see especially in the rain with all the road spray. This is one reason that we at ALTA thought it was VERY important to offer the Go Mini Go Brake Pulsar on our web site.
Two versions are available. The original unit which pulses about 4 times in about one second. Now a unit which pulses about 6 times in about one and one-half seconds. This unit will flash your third center brake light in the first 1 or 1.5 seconds after application of the brakes. Once applied and after the initial flash pattern the lamp will remain on solid until pressure is release and or reapplied to the brake pedal.
Try one today to see how quickly folks behind you take notice. Click HERE to check it out on the ALTA web site.
Want to really BLAZE a beam of light ahead? Check out the ALTA light bar for the R53 Cooper S Was $399.99 On Sale for $379.99
More Winter Motoring Products Coming Soon From ALTA!
vbmike
Oct 15, 2015 04:32 AM
