O.Z. Ultraleggera & Wilwood
Old Mar 14, 2007 | 07:01 PM
mangotangoe's Avatar
mangotangoe
Loking to purchase a set of 17" Ultraleggera wheels, et37, 215/40-17 Kuhmo SPT tires. Does anyone have any experience on whether the TCE Wilwood 11.75 big brake kit will clear? My dilema is that I don't think I will be able to use a spacer with the et37 wheel...
Any comments appreciated.
Old Mar 14, 2007 | 07:18 PM
txwerks's Avatar
txwerks
They should fit no problem - Alex@tirerack can tell you for sure. I am running OZ Ultralegerras in 16x7 with +37 over our Brake Man kit - with 12.19" rotors, and there's plenty of clearance. But, as we know, all BBK's are somewhat different!
Old Mar 15, 2007 | 09:09 AM
wohi's Avatar
wohi
Yes, should fit.
I'm running OZ Superturismo WRC 7x17et40 over the TCE Wilwood 12.19 BBK (same calipers) - also plenty of clearance.
Old Mar 15, 2007 | 05:59 PM
mangotangoe
Thanks for the responces. Alex@tirerack has been good enough to offer to measure an actual wheel. Will post his findings.
Old Mar 15, 2007 | 06:09 PM
txwerks's Avatar
txwerks
Alex is da bomb! (Just wish I could buy my Hankooks from them - or that they'd convince Yokohama to import the AD-07's in MINI sizes!)
Old Mar 19, 2007 | 02:40 PM
mangotangoe
Would I be correct in that this wheel with ET37 would have more caliper clearance than the same wheel with an ET42 ?
Old Mar 19, 2007 | 06:26 PM
txwerks's Avatar
txwerks
Well, that totally depends on the wheel design... But, the OZ Ultraleggeras have loads of clearance.
Old Mar 19, 2007 | 09:23 PM
mangotangoe
With the spoke design of the ultraleggera, I can see that the wheel would appear the same regardless of ET. However, on a wheel like the ASA AR1, would the outer lip get larger with an ET37 vs. ET42 ?
How BBK friendly are the ASA wheels, specificaly the AR1?
Old Mar 21, 2007 | 08:18 AM
Alex@tirerack's Avatar
Alex@tirerack
Et38 - 25 mm lip
Et42 - 30 mm lip
The ET 38 offers 4mm better brake clearance.
Kit freindliness depends on the kit. Witch did you have planned?
Alex
Old Mar 21, 2007 | 11:01 AM
mangotangoe
Thereofore, on the Ultraleggera all the diff. between et37 and et42 is in the hub. With the et37 being more brake friendly.
Have the 11.75 wilood race kit and was hoping that you would get back to me with the measurements off the OZ wheels.
Old Mar 22, 2007 | 06:35 AM
Alex@tirerack
17 + 18 will fit!
Alex
gar56
Nov 15, 2016 06:41 AM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
