Tire Pressure for P215/35WR-18
Old Sep 20, 2006 | 11:31 AM
Yangsen's Avatar
Yangsen
I recently purchased a set of O.Z with P215/35WR-18 Pirelli PZero Nero M&S XL.
The tires came with 40 psi but somehow they seemed to be slightly on the flat side to me. Is it just because of the low profile look or should I be running at higher pressure?
Thanks in advance for all comments and advises!
Old Sep 20, 2006 | 04:04 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For all MINIs you always follow the recommended tire pressures on the door jam plate of the driver's side.
Doesn't matter what the tire looks like if you have the correct psi inflation.
For the MC about 34-35 psi and for the MCS about 35-37 psi especially with four people.
I don't recommend 40 psi to any MINI owner for general use.
Check tire pressures first thing in the morning when tires are cold.
If the tires were checked in the sun or late afternoon they might be slightly higher than in the early morning.
Old Sep 20, 2006 | 08:03 PM
Yangsen's Avatar
Yangsen
Thanks alot for the reply. I will check again in the morning when the tire is cold.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
