Info on 15" wheels & track tires?
Old Jul 3, 2006 | 02:41 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Am thinking that 15's might be the way to go...Lower the car, get a little help with effectively getting a lower final drive gear ratio, lighter wheels, etc. Anyone out there a dedicated track junkie like me with similar thoughts or who has done this? Recommendations for both wheels, tires..or...on the other hand, who wants to take the opposing side and dissuade me?
2005 MCS w/ltd. slp., no sr
15% HELIX pulley
HSport Springs & rear lower control arms
ALTA CAI
MILLTEK cat-back
ss brake lines
Hawk HP+ f&r
Old Jul 5, 2006 | 02:59 PM
Alex@tirerack's Avatar
Alex@tirerack
225/45/15 - all day long!
I have had luck with 205/50/15 Pilot Sport Cup also!
Alex
Old Jul 5, 2006 | 03:36 PM
matma92ser's Avatar
matma92ser
I use 205/50/15 on the track. Should work great on most tracks except the faster ones where you start running out of RPM because of the smaller rolling circumference. Also note that your speedometer and odometer will show higher than actual.
Alex - Is that 225/45/15 on a MCS? What offset and size wheels, how much lowering, and is there any issue with rubbing?
Old Jul 5, 2006 | 03:44 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Currently Using holies with the 205/50/15 for Autox.. have on order set of Hannibles 15x7 with the Toyo-ra1 225/45/15. there is a slight problem with rubbing so ive heard and either a 5m spacer or slight modding of front fenderwell took care of it.. once i get them in if i have an issue ill post it.
Old Jul 5, 2006 | 03:48 PM
dmh's Avatar
dmh
I've got a set of scrubbed Kuhmo V710 205/50-15 for sale in the Marketplace. Something like $45 each.
Old Jul 5, 2006 | 03:53 PM
StallionAJG's Avatar
StallionAJG
I'm running 205/55/15 on the street . . . it keeps the speedo a little closer to accurate and me a lot less likely to bottom out, but I still get the benefit of slightly lower gearing, lower weight, and a smoother ride. I'm running Toyo Proxes T1R's and not having any problems with the sidewalls rolling.
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
eatsleepautox
Oct 30, 2015 06:46 AM
Mini'mon
Aug 16, 2015 04:15 PM
Dashdog
Aug 10, 2015 06:17 AM
PatrikKN
Aug 5, 2015 09:10 PM
