Brake Clicking Sound after upgrade
Old May 23, 2006 | 05:20 AM
iceman30's Avatar
iceman30
I replaced all my brakes this weekend with brembo blanks and Hawk HPS pads. I also swapped out the brake lines to stainless.
When stopping moderatly, I hear a clicking sound that slows with the car. I am almost willing to bet that it is coming from the front passenger wheel. It doesn't seem to effect the braking, but i haven't really pushed the car yet. The pedal doesn't seem to grab as much as it should with the new lines and pads though.
I have rechecked the bolts on all four calibers, rotors. Unbolted both fronts and reloaded them.
The only thing I haven't done is re-bleed them, i used the old fashioned way...pumping, rather then preesure bleed. Does anyone think that could be it? Or any other suggestions?
Old May 23, 2006 | 05:59 AM
polmear's Avatar
polmear
try an application of anti-squeal lube to the pad plates. also re-bleed...pumping is a perfectly usable method.
Old May 23, 2006 | 07:07 AM
iceman30's Avatar
iceman30
plenty of anti-squel...i can re-bleed tonight hopefully....
Old May 23, 2006 | 07:21 AM
polmear's Avatar
polmear
maybe you have an excess of the lube, also, how firm are the springs?
Old May 23, 2006 | 10:55 AM
toddtce's Avatar
toddtce
I have found this on a number of larger rear rotor kit fits. The pads are quite loose in the caliper for some reason. I isolated it down to the pads on one car to be certain it was not something rubbing on the rotor or hat. Taking them out and peening the backing plate a bit to keep it tighter in the caliper seemed the only solution. The ticking was exagerated due to the larger rotor in fact.
Old May 23, 2006 | 04:32 PM
iceman30's Avatar
iceman30
i will remove the caliper and try cleaning some anti squeal off and playing with the back of the pads...everything seems real tight though
Old May 31, 2006 | 09:22 AM
iceman30's Avatar
iceman30
seems like they have kind of worked there way out....it has only happened once since and it was under extreme braking.
Old May 31, 2006 | 10:25 AM
onasled's Avatar
onasled
Do these pads have the wire backs that lock onto the piston? Some 'race' pads do not come with these and they make quite a racket.
Old May 31, 2006 | 10:27 AM
iceman30's Avatar
iceman30
yea they did, they were exactly the same clips as the originals...maybe it was a touch to much anti-squeal, the rebleeding, or letting them just get situated in the caliper
W0TM8
Dec 19, 2019 07:50 AM
Aug 7, 2015 05:56 AM
