Flicks
Old Apr 4, 2006 | 06:32 PM
CARdiac's Avatar
CARdiac
Flicks
I picked up a set of Flick Wheels and had a question. I am told that the Hubcentric rings are a must- but will the stock lug-bolts work?
Old Apr 4, 2006 | 07:05 PM
kenchan's Avatar
kenchan
not a must... if they mount without any vibration. ive had wheels in the past
that did not use centering rings where the center hole was much larger than
the car's hub.
the stock lugs should work just fine.
Old Apr 5, 2006 | 05:16 AM
petecrosby's Avatar
petecrosby
I have 2 sets of Fliks; one set for the street and one for AutoX.
The stock lug bolts work just fine.
I would not mount them without hubcentric rings and strongly
recommend you get metal, rather than plastic, rings.
Old Apr 5, 2006 | 06:31 AM
stevecars60's Avatar
stevecars60
Do you have any idea where to get metal rings?
For years I'v mounted wheels without the rings. Almost all that are made are plastic & are there only to center the wheel when mounting.
The plastic rings can & do cause problems when they get old, they deform.
Old Apr 5, 2006 | 06:57 AM
petecrosby's Avatar
petecrosby
Try here:
http://www.discounttiredirect.com/di...501717191!NONE
Old Apr 5, 2006 | 06:58 AM
ej's Avatar
ej
Metal hubcentric rings
I picked up a set from: http://www.ezaccessory.com/
Might want to give them a call since I think the plastic ones were listed on the website.
Old Apr 5, 2006 | 07:06 AM
YDrvSlo's Avatar
YDrvSlo
metal rings from Discount Tire Direct
Call Discount Tire Direct @ 800-589-6789. $15 for a set of metal rings. Tell them the Mini hub is 56.1 mm, and tell them the hub bore of your wheels.
Old Apr 6, 2006 | 04:32 AM
stevecars60
Thanks guys. I'll be picking up a set......
that7guy
Off-Topic :: Autos
Mar 23, 2008 08:11 PM
k_h_d
Aug 22, 2007 08:04 PM
ekim
12
Oct 19, 2006 04:00 PM
CARdiac
Tires, Wheels, & Brakes
Apr 23, 2006 08:04 PM
daleCarlsbad
Oct 6, 2005 09:36 PM
