17s w/run flats = 18s with normal tires?
What I mean here... can I theorize that 18 inch wheels with normal tires will not be any more harsh than what i'm already experiencing with the bricks (run flats) I have now? Just trying to justify the switch to 18s
I like them at 35psi
Two options for 18" non runflat tire size.
First is 205/40-18. 40 series is not too low and 205mm width not too wide.
Selection is rather limited with runflats or only one non runflat at tirerack.com. Ask Alex@tirerack.com about the Michelin Pilot Sport PS2 for $189 each in stock. 220 treadwear AA traction 20 pounds, fits rims up to 8" wide, 24.4" tire diameter. See
http://www.tirerack.com/tires/tires....4YR8SPORTPS2XL
Second size is 215/35-18 which has a much better selection and better prices. Fits rims up to 8.5" wide. You can choose Extreme/Max Performance Summer tires or even All Season Ultra High Performance tires. 35 series is a bit stiffer sidewall but if you choose an All Season tire it should be OK and not overly stiff.
See
http://www.tirerack.com/tires/Compar...=All&x=57&y=10
Some All season Ultra HP tires to check out-
Continental ContiExtremeContact $124 each 21 pounds 400 treadwear AA traction 23.9" outer tire diameter
Pirelli PZero Nero M&S $140 each 20 pounds 400 treadwear A traction 24" outer tire diameter.
All Season tires usually give longer treadwear and reasonable traction for street use. Some give a comfortable ride as well.
See
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
real good information Minihune, and i agree on that. I switched to 18s with 215/35/18s from RFs and it felt just a little softer, nothing big. If you do 205/40/18s, would even feel more comfortable, although they are 18s.
Originally Posted by minihune
Yes, it is possible that 17" Runflats and 18" non runflats can be about the same in ride quality for street driving on most roads. Our sales people at the MINI dealership often remark that the JCW 18" wheels with runflats are about the same ride quality as the 17" runflats. So 18" wheels by itself can be ok.
Selection is rather limited with runflats or only one non runflat at tirerack.com. Ask Alex about the Michelin Pilot Sport PS2 for $189 each in stock. 220 treadwear AA traction 20 pounds, fits rims up to 8" wide, 24.4" tire diameter. See
See
See
See
See
Originally Posted by Rep. San Marino
Just put 215/35/18 on my car this weekend and it is a slight to moderate better ride than the 16" runflats I took off.
Kimolaoha
Dec 5, 2020 09:32 PM
