Depth of MINI hub and OZ Superleggera Questions
I'm designing some custom spacers with integrated hub rings for my OZ Superleggeras, and I was wondering if anyone knows the following:
- What is the depth of the MINI hub?
- What is the center bore on 17x7 OZ Superleggeras?
Thanks for any help!
-Strom
-Strom
Originally Posted by Passat774
Do you have the OZ hub centric rings? The nice metal ones that clip and retain in the wheel?
Your other option is to call OZ or take a wheel off and measure it
Spacers on OZ Superleggeras???
You're putting spacers on you OZ Superleggeras? Wow! I've got some 16" OZ Superleggeras and Bridgestone S03s. I get some tire rub on the plastic wheel arches with no spacers. I can't image what would happen with spacers added in. Could we have very different offset?
Where do you get the rubbing? I'm only putting the spacers on the front.
The real issue is that I am putting on smaller spacers, but want something that is hubcentric. I could put on plain 4 or 5 mm spacers, but they wouldn't be hubcentric. I currently have 10mm hubcentric spacers, but they're a little too much for my tastes. That's why I'm designing some that integrate the hubcentric design with the hub centering rings for Superleggeras.
Amazingly, I get no rubbing, though I'm on the stock '05 suspension and using 215/40-17 tires.
I think that my shorter-than-stock 215/40-17s allow me not to rub.
I'm going to have to use control arm adjustment and trimming to minimize the rubbing once I lower the car.
Oh. Don't forget to coat the hub side of your centering rings with some kind of grease so they don't stick to the hubs. That happened to me!
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
jrezzo
Aug 9, 2015 10:32 PM
