205/55 ZR 16's?
Old Feb 2, 2003 | 08:09 PM
jeremy99's Avatar
jeremy99
Will 205/55 16's fit without any problems on a MC (non-S) with the standard springs/suspension?
Looking to replace my 16" Daytona's & Goodyear Eagle Funflats with 16" SSRs and these tires:
http://www.tirerack.com/a.jsp?a=EZ3&...055ZR6FHSZ50EP
Problem is that the smallest they come in on 16" tires is 205/55.
_________________
2002 MC Indi Blue/White
Sport Package and Sunroof
Old Feb 2, 2003 | 08:36 PM
edlfrey's Avatar
edlfrey
Should be no problem. The stock diameter of the runflat is 620.9mm and you are replacing with 531.9mm ( about 7/16&quot or a 1.8% increase. The rule of thumb is + or - 3% without any problems.
Since your going a little taller your spedometer will be a little closer to correct also.
_________________
2003 Cooper VR/W Roof and Wheels, Black Interior, Cold Pak MFSW, DSC, OBC
Mods: Clear 3rd Brake Light, Stubby Antenna, Clean Visors
Old Feb 4, 2003 | 02:02 PM
jeremy99's Avatar
jeremy99
Thanks! So, anyone know if this will still look and handle OK (going to a "slightly" taller tire, but much better one?).
So - do you mean the speedo will be faster than actual or slower than actual? I'm thinking slower (less hub revs per mile) which would potentially mean slower to rack up miles on the odometer too!
These tires look awesome - the reviews by the customers rave about them too - rated best tire I could find on the Tire Rack site.
Old Feb 4, 2003 | 03:00 PM
Alex@tirerack's Avatar
Alex@tirerack
205/55 Firestone revoves 837 revs per mile. Your average 205/45/17 has between 850-865 revs per mile. Your odometer with read slower than your traveling.
Dan
Old Feb 4, 2003 | 06:54 PM
edlfrey's Avatar
edlfrey
The speedo will be slower than actual but with stock tires it is faster than actual so with the change in tires it will register closer to actual speed.
Is that as confusing as it sounds.
DNytAftr
Jul 23, 2015 05:48 AM
Btwyx
Tires, Wheels, & Brakes
33
Nov 27, 2012 02:48 PM
DUCTTAPE
14
Dec 1, 2011 01:34 PM
JAB 67
Jul 24, 2007 07:07 PM
