Rear caliper threads stripped
Old Jul 24, 2005 | 06:52 PM
DaKineMINI's Avatar
DaKineMINI
I was installing some defective Speed Bleeder valves on my rear calipers and ended-up stripping the threads out of one (valve kept leaking and I kept tightening ). Any fixes for this (like heli-coil) or am I stuck with getting new calipers? Anyone know the part numbers for the rear calipers?
Thanks for the input.
Old Jul 24, 2005 | 07:28 PM
supersand's Avatar
supersand
Sorry about your misfortune. I don't know too much about the brakes but someone else posted this cool site that has part info that you're intersted in.
http://www.realoem.com/bmw/showparts...35&hg=34&fg=10
Erik
Old Jul 24, 2005 | 10:18 PM
Eric_Rowland's Avatar
Eric_Rowland
I don't know if a helicoil is recommended for that application, but I certainly wouldn't trust it. Technically if you can get the bleed valve to bottom out in the caliper fitting you'd be ok, but bleeding would be a nightmare unless the helicoil was a perfect fit.
I would think a replacement caliper is the best solution.
Old Jul 25, 2005 | 01:00 AM
DaKineMINI's Avatar
DaKineMINI
Erik
Thanks for the link. Just what I needed.
Old Jul 25, 2005 | 05:46 AM
polmear's Avatar
polmear
Originally Posted by DaKineMINI
.... Any fixes for this (like heli-coil) or am I stuck with getting new calipers? ...
I wouldn't try a helicoil, unless they are rated for hydraulic pressure. If they can't hold under pressure, could put you in a very bad situation. you are definitely better off getting new calipers
Old Jul 25, 2005 | 11:27 AM
Wesport's Avatar
Wesport
You could have a machine shop tap it out for a larger size bleader, but there would have to be a plan to keep metal shavings out of the piston area.
Old Jul 25, 2005 | 01:22 PM
polmear's Avatar
polmear
That depends on what size the bleedscrew currently is. There aren't too many thread sizes available for bleedscrews. Another concern would be fouling the seating surface.
Old Jul 25, 2005 | 02:30 PM
neilgj's Avatar
neilgj
Have you thought about checking out any salvage yards for used calipers?
Old Jul 25, 2005 | 02:50 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Time for a BBK!
Old Jul 25, 2005 | 02:57 PM
DaKineMINI's Avatar
DaKineMINI
Used caliper would be great but I'm in Hawaii and we are limited when it comes to salvage yards. I got a quote from Classic for $176 so I'll probably end-up ordering from them.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
squawSkiBum
Oct 2, 2015 09:21 AM
StealthR53
Aug 8, 2015 10:59 AM
