So, how much energy is in the wheels, and how much benefit is there in going lighter?
Mat, I'd agree with a contribution of weight somewhere in the range of 2-4x the wheel/tire weight, but you are using an artificially small difference by using 17 lbs. and 20 lbs. as examples.
How about a 13 lb/corner difference between 22 lb. 18" JCW wheels (large radius) and 9 lb. 15" SSR Comps? The perceived difference is a lot closer to the .3 sec. to 60 mentioned in the SCC article, than the .1 sec. figure that you prefer.
BTW, the article is quite clear that the .3 sec. figure is accurate, although a good chunk of the difference is in rolling radius.
Also, the difference in adhesion over bumps due to the lower unsprung weight and greater tire compliance is night and day. You don't see WRC cars on 18" wheels unless the stage is on dead-smooth new pavement or a track.
I concur with flyboy and the good Dr.
1# off the wheels equivalent to about 1.6-1.8# off the chassis.
The decrease in sprung/unsprung weight definitely improves
handling on rough roads also.
Originally Posted by chows4us
0.1 sec difference for 0-60 mph means that its all human driver error in the difference
So much for dropping $1K on lighter wheels
In the end, I can't see spending big dollars on a MINI (wheels, brakes, high-$ suspensions, etc.). It's not and never will be a sports car. Adding thousands to the purchase price gets you too close to the purchase price territory of true entry-level sports cars, like the Boxster or perhaps the upcoming Z4 Coupe. Trying to get a MINI to perform at Boxster level puts you in a high unreliability territory, and would potentially kill resale value, or at least considerably narrow the perspective buyer market.
My appreciation of the MINI is that it's a fun commuter car, even bone stock. My disappointment is that it takes so much effort to drive consistently fast on the autobahn, and at speeds over 100 mph it's incredibly inefficient. Considering all this, I know I've made my last mod.
Your missing the point....
Originally Posted by OldRick
Matt, I'd agree with a contribution of weight somewhere in the range of 2-4x the wheel/tire weight, but you are using an artificially small difference by using 17 lbs. and 20 lbs. as examples.
If you do a larger weight savings by using 13 lb wheels, you still get that 1.6ish difference, just with a larger weight to multiply.
the only way to get greater than a 2x improvement, is by actually reducing the diameter of the overall wheel/tire combo.... But then you start messing with contact patch, effective gear ratio and the like...
Matt
Originally Posted by Stevie B
Same applies to braking distances. I'd argue that optimal reaction time or stronger brakes, and especially combined, would do far more for shorter braking distances than lighter wheels could ever. With that one could argue that lighter wheels is a variable and the same driver is a constant; therefore the lighter wheels equals consistently shorter braking distances, but stronger brakes should beat lighter wheels. With that though, the money in brakes only gains braking efficiency while lighter wheels creates gains across many performance areas. So lighter wheels may be the better spent money, but the performance gains are so small that these mods are all low bang for the buck, especially when considering the ratio of mod cost to the purchase price of the MINI. Since there's MINImal (couldn't resist) return on the mod investment, I think you have to be careful if you don't plan to keep your car for a long period, provided resale is important to you.
Tire/road contact can be improved by decreasing the the tire and wheel weight and improving the suspension geometry. Of course, if you choose to reduce the the tire/wheel weight by going to a smaller size, you will also reduce the tire's contact patch, so you must find the right balance here or risk a self-defeating cycle. I won't get into rotational moments and such because I am not that smart and it makes my head hurt. There are other, smarter people around here who get into that sort of thing.
Tire stickiness, well that is self-explanatory.
The rub comes when you must do repeated stops or modulate your braking (perhaps if you do not have ABS).
Changing rotor and caliper size and shape - and the master cylander and brake fluid if necessary - will merely change its ability to absorb and transfer heat - not shorten braking distance (may actually hurt it in some cases - unsprung mass and rotational moments - arg! head hurting again). Very helpful if you are on a track and the brakes have soaked up all the heat possible.
Improving brake feel by switching pads and installing steel brake lines will enable you to better control your braking up to the point of lockup. New, premium fluid can help with as well, particularly if it is old and contaminated. In the dry however, ABS will usually do a better (read shorter and with more control) job at stopping a car than the average driver.
Some other comments on unsprung wieght savings...
If the part doesn't rotate, it's multiplier is 1x, like wieght savings from lighter calipers....
And for lighter rotors, you need to do the math. Most of the wight savings usually comes from Al hats that are near the axis of rotation, and the diameter increases..... Getting hit in the R-squared contibution to the moment of inertia.....
But they all do contribute to suspension response, that is only dependant on linear, vertical motions...
Matt
Matt
but
Earl
Well, the math is off a bit...
Originally Posted by 10851CS
The other part of it is this: I have SSR Comps (at 12.9 lbs) like the looks of the SSR GT7 (at 16.8 lbs) and I asked Alex at Tire Rack what the difference in weight would make and he said, "It would be like carrying 60 lbs around in your MINI at all times.
Earl
Earl
15.6 times 1.6 is about 25.....
So he missed by a factor of 2 (about).....
Matt
Since taking delivery of my Mini, I have subsisted on a diet of raw carrots and tofu, and run 15 miles each day, followed by long sessions in the sauna. I am now down to 135 lbs., thus saving 30 lbs. of useless driver weight. I do tend to get a bit dizzy and lose focus while driving, but I believe I have shaved perhaps .5 sec.. off my rolling 5mph to 60mph time. I do not allow my fiancee to ride in the Mini with me, thus shaving another 110 lbs. of useless passenger weight - in fact, I have welded the passenger door shut, thrown away the spare tire (that's what AAA is for) and the side view mirrors (I can turn my head for Chrissake). I would welcome further ideas for weight reduction . . .
Dr Obnxs, what change would you have calculated for the conditions in the article?
Earl
Earl
OK, so what? Like you never have to carry anything in the car? stuff from the store? a wife? kids? Dogs? Who cares? (UNLESS your trying to win a TRUE road race or AutoX) for daily driving, what does it matter?
Originally Posted by MINIotaple
And what if I am?!
But, far us pedestrian types, it dont mean much of nothing.
Hmm, just think, maybe those German engineers got it right.
... It's not and never will be a sports car. Adding thousands to the purchase price gets you too close to the purchase price territory of true entry-level sports cars, like the Boxster or perhaps the upcoming Z4 Coupe.
Do other cars like the Honda 2000S not qualify as a "true sports car"? I'm just wondering because I thought I drove sports cars most all of my life (and know the MINI is not one) but I never considered $60K to be "entry level"? I'm curious ... are our concepts of money that far off?
Originally Posted by Thameth
Whoa looks like we have a few too many math professors here on NAM.....
nonononono! more math professors!! less "math? we don't need no stinking math" hyping vendors and 3rd hand anecdotes from my-brother-in-law's-friend-down-at-the-service-station.
And maybe there was a bunch of compramise in the design...
In that case, see Onasleds gutting car. Thats should inspire you to get rid of all that extra weight.
What's the big deal if someone wants to shed some weight (I know, my wife would love it if I did, she doesn't really care about the car though...)
Every ounce shaved contributes to an improved power to weight ratio. Where is it written that cars come from the factory with the "perfect" number? Where is it written that there is a perfect number?
I can accept you saying "These kind of differences don't matter to me" but I think it's a bit off base to assume that all of the enthusiasts have your same perpective.
If I'd known (when I bought the car) that the S-lites were anything but light, I wouldn't have gotten them. Also, when you factor in that unsprung wieght advantages can have good effect on handling and braking as well, I can see that there are lots of people that would matter to.
And just because someone wants to get some of the benefit of reduced mass, there's no reason to postulate that they have to go "all the way" to gutting the car of all accessories, sound insulation etc. Heck, I like my lighter wheels, and I like my cup holder too! What's so wrong with that?
As many posters have pointed out, there's nothing wrong with making your car the way you like it, and there's no law saying that "way" should be the same one anyone else wants or even cares about.
Matt
...but I never considered $60K to be "entry level"? I'm curious ... are our concepts of money that far off?
Sorry for all the OT banter...
All I can say is I'm glad for MINI2 so that when I ordered my MCS I at least knew I didn't want to keep the S-lites. Luckily here in Germany they'll take your stock wheels on trade so I got R99s for only an additional $300 at the time of delivery. Yeah, I only shaved 3 pounds per wheel but I know the wheels are a lot higher quality than the S-lites. Look a little better too. Can I feel the performance gain? No way. I really wanted to buy a set of BBS or OZ wheels, which I could have done through the dealer, but spending another $800 or $1000 to shave off a few more unnoticable pounds just didn't make a lot of sense to me. Now that I've decided to sell the MINI in a year, I'm glad I made the decisions I did. I'm hoping the Koni FSDs add a little to the MINI in resale. They'll undoubtedly help resale.
Originally Posted by Dr Obnxs
as there is in ALL CARS!
"To each their own" Their money ...
I was calling myself "pedestrian"
More like $40K for the standard Boxster w/o options ...
Nice catcht!
The author there found that a pound on a tire tread is like 2 lbs of car weight, and a pound on the rim of the wheel is about 1.5 lbs.
The interesting stuff about the flywheel can also be applied to the lighter crank pullies as well, although the formula doesn't quite translate perfectly... (this is because a flywheel is basically a uniform disc of metal, and the crank pully isn't). But what it comes down to is that the lighter flywheel will kick *** over a lighter crank pully (more mass reduced, and a greater radius of the item). Too bad is such a pian to change the flywheel.....
He did get a bit sloppy in one of his sentances though, but it contained so much well explained stuff, that I'll forgive him for that one!
Matt
thanks for pointing this out Alex.....
Matt
...Dave writes some intersting articles...
So my 19lb Michellins and 16lb BBS wheels fair much better when compared with the stock runflat fair. I remember reading about this 'stuff' in Road and Track years ago. I've since installed Wilwoods 12.2 brake kit on my car. The floating rotors help to dissipate heat and the entire kit is about 11 pounds lighter than stock. However, that huuuge rotor - not including the hub - is quite a bit heavier than the stock garden variety rotor. I've taken one step back and three steps forward.
It's not that bad...
the rotor has a radius of just over 6 inches, and the tire 12. A pound off the tread is like 4 lbs at the edge of the rotor. And the rotor is an annular disk, so the rotational mass is distributed over a disk with a max radius of 6"....
So you won on unsprung weight, and won big on rotational mass.
Matt
Matt
